- Jul 30, 2006
Ok folks. This is a bit off topic. But we do tend to stray off the main path a bit in Traditional, so I will ask you to bear with me. Y'all can always just skip on to the next post if need be.
Recently I purchased two yeller Case knives with CV blades. One is a three spring stockman. The other, a two spring yeller sowbelly. I've mentioned them elsewhere.
The other day I measured the Rockwell hardness of one blade from each. The results were:
Sowbelly: 41
Stockman:55.6
Now, I've carried and used these knives enough to know that the edge retentions are about the same. Not phenomenal, but adequate. How can that be? you ask.
The answer lies both in the measurement technique and the methods of making a traditional knife.
First the measurement. To measure the Rockwell hardness, you need a sample which is flat with top and bottom parallel to one another. On most traditional knives, that means you have to measure the tang.
Now the knife making part. To fit three blades onto two springs, normally the blades have to be bent or to put it in cutler terms, "crinked". To do that, you have to soften the tang.
The sowbelly has three blades on two springs. The blades are most definitely crinked. Therefore, the tangs have to be softened. So the 41HRC I measured applies to the tang, not the blade.
The stockman has three blades on three springs. The blades on my stockman are straight. Therefore, the tangs do not have to be softened, and on mine, they obviously were not. The actual blade hardness is 55.6HRC.
In the past I have measured the hardness of several different traditionals:
Case CV Sodbuster__54__straight blade. tang not softened
Camillus stockman__42__crinked blades. tang softened
Camillus stockman__42__crinked blades. tang softened.
So. My conclusions are this:
Sowbelly: 41
Stockman:55.6
- If you are measuring a hardness in the low 40's on a traditional knife, you may be measuring a tang that was softened
- Case CV blades are hardened to about 55HRC. This is a fairly common traditional hardness range, though a little softer than I would like. It has been reported that GEC claims a hardness of 58 for its 1095 blades. And it was reported that Camillus used to harden its 0170-6C blades also to about 58.
