Got's my popcorn...this is GREAT!
Thanks, Folks!
+1 :thumbup:
Thanks, Folks!
Everything is a trade-off and in the end if the knife does what you need it to do, then it is clearly up to snuff.
For my knives, it's 59-60 Rc. The extremely fine grain of W2 allows a tough blade at this hardness and is still fairly easy to sharpen. But holds a fine edge for a relatively long time.
If I had to guess the Rc of the newer Cv blades based on my use, I would say mid 50s'. I'll rockwell test a newer CV blade next chance I get and report back.
Regarding the annealing of the tangs, I believe that Case anneals the tangs on all pocket knife blades, regardless of pattern. When I toured the Case factory last fall I was told that there are several reasons for the annealing...blade crinking as required, but also to give the blades more of an ability to "flex" slightly in use therefore less likely to break, and to reduce the potential of wear on the tang.
Steve did you mean to say wear on the back spring instead of tang end?
In my experience the tangs wear first on Case knives as well as other Mfg.s knives......
I agree that a harder steel is easier to get sharp, or get sharper than a soft one. What I meant was how it felt on the stone, the steel felt harder and took a bit longer to get sharp, if that makes any sense.I don't think hardness = difficult to sharpen. In fact I have a fully hard 1095 blade that is very easy to sharpen. I can even use an old Arkansas stone to sharpen it. I think wear resistance is the factor in a steel that can be hard to sharpen and not the hardness. Heck I even think the harder blade is even a little easier to get sharp than a softer blade. Case blades in the rc 40s? WOW that is soft. I sure hope they are much harder than that now. I'm willing to bet my CV SwayBack is harder than that. That is the only Case I have right now.
Thanks, Folks!
Rockwell isn't everything.
wow so much great info.. and it all started cause i decided to buy a case trapper in CV and was curious about the steel and how people liked it. i gotta say it seems easy enough to sharpen and takes a wicked edge
thanks guys!
I couldn't have said it any better. Regardless of what the hardness of my Case CV Swayback is, it is some good stuff.Edge geometry is probably the most important factor of a good knife experience.
But if the Rockwell hardness is too low it will not be as good.
