- May 15, 2013
Rockwell, resistance, and overall personal experience.. what do you guys prefer and like for a user knife. Let say for example a Vic Alox Soldier and a Case Sodbuster CV.
My experience with these steels might be best explained with beer. And ale. (We can talk about tea and coffee if that is better or red and white wines) Which is to say, there are big difference and smaller differences.
Most people can tell the difference between beer and ale (or tea and coffee). CV is considered to be a carbon steel. It has some vandium in it, hence the 'v'. Other carbon steels include 1095 (GEC, old USA Schrade and many others) and X90 (Opinel). This is tip of the ice berg. Victorinox INOX is a form of stainless. Huge number of forms of stainless and many more opinions about them. Carbon steel tends to take a fine edge, sharpens easily and is tough in that it usually resists chipping; all properties that have made it a traditional favorite for working knives. Stainless resists corrosion and the properties of the various forms of stainless vary wildly.
I'm still working my way around "tasting" different carbons. Haven't used Case CV yet but hope to. I can say that I can tell a difference between Opinel's X90 (which I believe is hardened around 55Rc) and old Schrade USA 1095 (which I believe to be hardened up in the 58Rc range). The Schrade 1095 takes a bit more time on the stones to sharpen and I picked up one used Schrade that had been badly treated with some noticeable chips in the edge. But, they hold their edge for a long time when working with wood. I can sharpen my Schrades down to 20 degrees/side with no edge folding. My Opinel Carbones (which I treat horribly) will not hold an edge as long and I've dented edges and folded edges but never ever chipped an edge. My sense is this is primarily the difference in hardness. Not sure where Case CV is hardened to, or GEC for that matter. This thread suggests mid 50s for current Case CV and around 58Rc for GEC 1095.
http://www.bladeforums.com/forums/showthread.php/740432-Case-CV-Has-it-changed
I have stronger feelings about Victorinox INOX. I think its only hardened in the 53-55Rc range. Some find it easy to sharpen but I find it forms a burr so easily that it's hard to get rid of the "wire edge" that forms. I'm unimpressed with its edge hold too. I like it worse than Case's SS (reported to be 420HC at 55Rc) and like Case SS noticeably less well than Bucks 420HC (58Rc). Just starting to play with Opinel's Inox (Sandvic) and so far it feels very similar to Bucks 420HC. Buck's old 440C is another animal all together.
Notice, btw, that we're starting to get into discussions that sound very much like differences among IPAs (or coffees).
A reasonable approach here is to pick a knife you like and don't worry about it.
Or, if you want to worry, lot's of good reading here.
http://www.bladeforums.com/forums/showthread.php/368828-Steel-FAQ
Interesting thread, thanks for the info. So it sounds like good ole 1095 is pretty hard to beat for a general purpose working knife?
Well written. I like your style.![]()
One thing if I may... Opinel carbone is XC90 (equivalent aisi 1086). X90, I believe, is a stainless steel.
I thought SAK steel was pretty close to 12C27, if not it. I think overall I prefer these type steels to the super steels. I can get SAKs and Cases (ss and cv) and 1095 wicked sharp pretty easily and I guess I don't use em hard enough to have to repeat often enough to worry about it. I guess it is because I enjoy sharpening. I haven't gotten to the point of appreciable material loss or my mind would change or if i processed game.
"Q. What is the makeup of steel?
A. All Victorinox knives are high carbon, stainless, first grade, A-quality stainless steel, x 50 CrMo. They are tempered to a 55-56 HRC hardness for optimum edge retention."
(...)The Victorinox steel on the other hand is pretty much impossible to get it to rust. I have an Executive that went through the same sort of abuse for years. If you rust the blades on a Victorinox SAK, you've really done something.
Guess this makes me special.
I managed to rust one of mine, after leaving it in a toolbox in the covered bed of my pickup for a couple years or more (in central Texas). I'd completely forgotten it was ever in there. The blades & tools were stuck shut with rust; had to soak it in WD-40 for 3-4 days to loosen it up, before I could finish cleaning it up. It's visibly pitted now, and some of the implements still won't snap shut on their own, but my Vic is at least functional again.
David
This info, and the quoted text below, is straight from Victorinox's FAQ page (linked below):
http://www.victorinox.com/us/content/customerSupportVictorinoxSwissArmyKnives
This is the elemental makeup of X50CrMoV15 (as listed here -->: http://zknives.com/knives/steels/x50crmov15.shtml ):
Carbon = 0.50%
Chromium = 14.50%
Molybdenum = 0.65%
Vanadium = 0.15%
Manganese = 1.00%
Silicon = 1.00%
Elementally quite similar to the 12C27Mod stainless in Opinels, and higher chromium content than 420HC (might explain the pronounced burring & wire edge issues, at lower hardness).
David
