- Apr 12, 2009
Super helpful. Thanks! Interesting thought about the Chromium and burring at low Rc levels. I notice more of a difference between Vic's Inox and Case SS than I do between Opinel's Inox and Buck's 420HC. Weird.
I notice the same relationships.
There's a very predictable relationship between edge-holding, burring and wire edge issues, when you look at somewhat lower levels of carbon (~0.5%, give or take) and higher chromium (above 13%, more often than not) in the same blade, especially at lower hardness levels. All of the blade steels in which I've noticed issues with burrs and wires all have essentially similar chemistry in that regard. After a while, it's easy to understand why most cutlery steel wouldn't perform acceptably well with anything much below 0.5% carbon content, as the edge-holding really degrades below that threshold. Heat treat can only do so much, as it's largely dependent on there being enough carbon in the steel to be effective. Having said that, once you do get above that minimum threshold for carbon, heat treat makes most of the difference in how a particular edge will perform.
Chromium adds a lot of ductility to steel ('bendy', 'gummy' burrs & wires), which can be offset somewhat by treating to higher RC (best seen in the comparison between Case's 420HC and Buck's, with the only difference being RC hardness), OR by increasing carbon content in relation to the chromium. 440C is a great example: very high chromium at 16-18%, but proportionately higher carbon as well (1.2%), which has much to do with how well it holds an edge, without being too 'gummy' or ductile.
David
