- Mar 11, 2013
Thanks for sharing. I thought it was a larger model.Hello it’s a 6332.
It’s a pretty good size. Not small like the 6333Thanks for sharing. I thought it was a larger model.
Dang, that had me stumped for the longest time. Finally realized it's because (I think) we most often see the two blade version known as the Texas Jack (that's the 6232, which was later restyled as the slightly slimmer 62032 -- and I suppose issued as the 63032 also). Beautiful knife.It’s a pretty good size. Not small like the 6333
Love seeing that knife. Most underappreciated pattern in my opinion!!
Thanks gentleman. Its my favorite Case. I like the half stops and the size.Love seeing that knife. Most underappreciated pattern in my opinion!!
I can see why! I need to find one of these. I really like the 6344, which has the same blade combination (i.e., it has the pen instead of the usual stockman spey) but is slightly smaller than the '32, and also has the same square bolsters. It looks as if the '32 is about the same size as the '18.
I do find them similar in size closed length. I had an older 18 but the blades aren't full. So, I grabbed my new one.I can see why! I need to find one of these. I really like the 6344, which has the same blade combination (i.e., it has the pen instead of the usual stockman spey) but is slightly smaller than the '32, and also has the same square bolsters. It looks as if the '32 is about the same size as the '18.
Thanks for all the detailed info and pictures! Definitely something I will keep a watch for. Oh. My. Gosh. Looking at this made me remember... I do have a 1977 6232, and a newer 62032 as well as a 6318. I got them all out and I can see exactly what you are talking about. For one thing, I had it backward, the '32 is a bit slimmer than the '032. Also, the '32 is just a bit longer and has half stops. the clip blade on the '32, as you say, is much more robust than the '18. My '32 is darker than yours, but the color is similarly very deep and rich. Mine has very strong springs and the first time I opened it I caught a bit of flesh between the clip blade's tang and the bolster. Ouch!I do find them similar in size closed length. I had an older 18 but the blades aren't full. So, I grabbed my new one.
I find the 32 to be more of a workhorse though. The clip feels a little longer and has more heft than the Turkish/Californian/Muskrat clip on the 18. Both of these blades are full length, as can be seen by the way the rest in the blade well.
One thing to be careful with on the 32s is I think the 1979 years? They are transition pieces that use the 32 (not the 032) number stamp, but they use the 032 tooling. No half stops on those. I'm sure there are other differences too I'm not privy to.
Of the modern Case bone colors I think the Chestnut (common in the 1990’s and early 2000’s) capture the look of the 1970’s Case Knives the closest (not exact mind you). There is variety in the Chestnut too. More collecting opportunity for you. OHTrue. But when they make so many variants, why not make these still?
By design, the square bolstered 32 and 032 patterns have Clip main blades while the round bolstered 18 pattern has a Turkish Clip main (similar to the blade in a Muskrat). As both are Medium Stockman patterns I think the 32 was designed to be more robust and the 18 designed to be more compact in the pocket. I regularly carry both and can tell the difference when carrying the knife. OHthe clip blade on the '32, as you say, is much more robust than the '18.
Yes, there are differences here that I never noticed or appreciated. As you said, "More collecting opportunity...".By design, the square bolstered 32 and 032 patterns have Clip main blades while the round bolstered 18 pattern has a Turkish Clip main (similar to the blade in a Muskrat). As both are Medium Stockman patterns I think the 32 was designed to be more robust and the 18 designed to be more compact in the pocket. I regularly carry both and can tell the difference when carrying the knife. OH
Having "hijacked" this thread to talk about '32s and '032s, I thought I should contribute to the "color" question. Here is my 1977 6232. Going back to the passages that I quoted from Steve Pfeiffer's book, I would guess there is no intentional reason my 1977 is a different color from the 1976 other than normal variations in the bone and the dyes that were used.
Keep in mind that in the 1970’s Case used brown jigged Delrin interchangeably with brown looking jigged bone. The reddish bone is easy to tell apart but some folks have a hard time with the Delrin. Best way is the edge, color of the Delrin will be a solid brown, brown colored bone will be porous looking on the edge. OHI have searched, but can't find a good answer for my question.
In my youth, my first knife, and that of many of my friends, was a Case Stockman in kind of a brownish jigged bone with the oval shield similar to what now comes on the yellow delrin models.
Many of our parents carried the same.
What was the color of that bone called? And it seemed to be the standard offering for many years, why do they no longer do them that way?
I was just taking pictures to get "back to bone color"Having "hijacked" this thread to talk about '32s and '032s, I thought I should contribute to the "color" question. Here is my 1977 6232. Going back to the passages that I quoted from Steve Pfeiffer's book, I would guess there is no intentional reason my 1977 is a different color from the 1976 other than normal variations in the bone and the dyes that were used.
Oh, and one other '32/'032 difference -- this 6232 has a pinned shield.
That's a good point and a valuable piece of this information for this discussion. Yes, Delrin will be a uniform brown, while bone has a depth and richness to the color, possibly with noticeable variations from one part of the covers to another. Here are two 1977s, an equal end jack in Delrin on top and my 6232 jack in bone on the bottom.Keep in mind that in the 1970’s Case used brown jigged Delrin interchangeably with brown looking jigged bone. The reddish bone is easy to tell apart but some folks have a hard time with the Delrin. Best way is the edge, color of the Delrin will be a solid brown, brown colored bone will be porous looking on the edge. OH
I believe there is also some rule that most early bone has the circle around case in the oval shield whereas most early delrin does not.That's a good point and a valuable piece of this information for this discussion. Yes, Delrin will be a uniform brown, while bone has a depth and richness to the color, possibly with noticeable variations from one part of the covers to another. Here are two 1977s, an equal end jack in Delrin on top and my 6232 jack in bone on the bottom.
Yes! And then at some point they swapped this and now the synthetics have the circle.I believe there is also some rule that most early bone has the circle around case in the oval shield whereas most early delrin does not.
Edit: seems like this might've been true from approximately '74-'85.
