- Jan 11, 2015
The only Mariners I've seen have the marlin spike as part of the knife. I was not aware of these sets which used the folding hunter model.![]()
Oh I believe you David. Just new to me.This is a 'Mariner's Knife Set', of which the 6265 SAB Folding Hunter knife was a standard component included with the separate marlinspike and scabbard. Not to be confused with the 'Rigger's Knife' pattern '46, which included the folding marlinspike.
David
The knife is a 6265 SAB Folding Hunter; maybe stainless if 'SS' follows the '6265 SAB' mark (should be on the backside of the main clip blade's tang). The 'CASE XX' tang stamp visible in the 2nd pic would indicate it's no more recent than the 1970s, and might be a 1965-'69 knife. If it's 1970s-vintage, there should be some visible 'dots' underneath the 'USA' stamp on the tang (sometimes partially obscured under the pivot/bolster; use a magnifier and open/close the blade partially to see them). The number of dots would give a clue as to the specific year, starting with 10 dots for 1970 and removing one dot for each subsequent year; ending with only one dot in 1979. The 1965-'69 range will not show any dots at all under the 'USA' mark on the tang.
The scabbard and marlinspike were part of a Case-produced 'Mariner's Knife Set', which included the standard 6265 SAB Folding Hunter knife. I have one of these sets with 1981-vintage knife (SS), though it likely wasn't the original knife with the set; I think it was swapped out before I acquired it.
David
Case offered those from about 1957 until the mid 1980's. Starting in 1972 when the 6265 in SS was put in production, they offered the Mariner's set in both CV and in SS. The posted knife is from roughly 1974 to 79 based on the visible stamp and the "composition" shield (no oval around CASE).
That looks more like a Case Hunter instead of a Mariner.
I was confused in the lack of the oval as there is no oval on the stamp, however not a SS and no dots on the tang, hence leads me to 1969, but your right the lack of the oval leads to a 1970,s knife
Hmm..... Well maybe...
It would help if old dad could remember he bought at Navy Exchange was active duty 1967-1969 but remained in the Reserves for 20 years after and frequently shopped at the exchange and can only remember he bought before I was born which was 1974
Maybe there are some "x"'s on the tang and just can't see them as the tang stamp is somewhat obscured into the bolsters and brass liner definitely stamped 6265 SAB
1965 was a transitional knife too David as that is the year that Case introduced the thong hole in the rear XX65 (Folding Hunter) End Cap. Supposedly they used the thong hole starting 1 January 1965 but as with most things Case (and most other manufactures), there were always holdovers from the non-thong hole knife parts that carried over into the new variations. Therefore, there were XX65s made in 1965 that had no thong holes - most likely through the first two or three months of 1965.
