- Oct 17, 2009
I actually like the scales, even though they aren't as advertised. On mine they are dark red for the most part and fade out to a lighter red toward the bolsters, but not so dramatically as I've seen on other red scales. I like the contrast and think this one will age well should I choose to keep it, and that's looking more likely.I assume this is the Tony Bose teardrop jack?
I have one in ebony (and Tony Bose's signature laser etched on the blade). I was disappointed when I bought it because it had a lot of blade wiggle. Some whacks with a rubber mallet fixed that, and the pivot is tight now, yet still retains all the snap it had before. And it does snap. In all positions. Physically and audibly. Pull on mine I'd rate about a 4. Definitely lighter than most, but not weak. It's maybe a slight tad stiffer from half-stop to open than closed to half-stop, which helps with the "walk" part of "walk and talk".
All in all, I'm very happy with the knife. I wouldn't mind if the pull was stiffer, but being a "dressy" knife, I feel it's appropriate for it to be a bit lighter.
If you're not happy with yours, definitely send it in. Send it back if you're disappointed with the scales, send it to Case if all you want is the action fixed. A few years back I got a "dark red" bone Case and was disappointed in the dull salmon color it actually had. Most real-life pictures I've seen with this bone have been the same. However, that's the only option (that I can find, at least) with 2 blades in CV steel except for bonestag and whancliffe main, so you might be stuck with the not-so-dark dark red.
I did a more thorough cleaning with carburetor cleaner and compressed air and it improved slightly, perhaps enough to be considered acceptable.
The pen blade still isn't very satisfactory but the main blade has a nice snap from half-stop to open. Pretty much as you described.
