- Jan 3, 2013
As been mentioned, a fine wire edge may roll or fold and make the blade feel quite dull. I strop or drag the blade through some wood in order to break that edge. The steel seems to work pretty good once done.
That really does sound like a straightened wire edge (burr) folding over on you.takes a screaming edge easily and then loses it almost immediately. Once went from shaving sharp to 'won't cut paper' after opening a thick cardboard envelope.
I only have a sharpmaker and a strop. That's the thing, the knife is so cheap and other knives work so much better that I don't feel the drive to bother trying to force it to work. I did EDC it for 6 months but a SAK holds its edge far longer, cuts better and doesn't require workarounds when sharpening.That really does sound like a straightened wire edge (burr) folding over on you.
On the original topic - you know, I can't really tell you. I know I can make a Tru-Sharp blade pretty sharp. But my cutting needs are so limited that I hardly put enough stress on those sharp edges to tell you how long it holds up. I bet that if I were a very frequent knife user that I could tell you how well the edges last, but I am not. So they seem to last pretty much forever for me, once I get them sharp in the first place.
Your best friends, when learning to sharpen, are a very bright light, a marker pen (Sharpie), a high power magnifier like a loupe, and some time and patience. It is when you look at an edge and see "aha, I see what I did there" and then go back to the stones with that new insight, that you make progress. After a while of doing that, somehow your hands and eyes and ears learn what they need to know. Also - the sun and moon must be in the right alignment.
In general, I like Case Tru-Sharp stainless. I have gotten lazy and end up stopping after a 400 grit Norton India "fine" and de-burring on loaded leather strop. I have gotten, on rare occasions (sun and moon aligned) true "hair tree topping" sharpness from that process on that steel. On bad days, just regular shaving sharpness.
Don't be shy with this steel. Hit it with a coarse stone until you get a burr on both sides, deburr, then refine that fully apexed edge. It will cut.
One thing I have noticed, and others have posted as well, is that those ceramic stones seem to be very prone to creating a wire edge on the "gummier" steels like Case Tru-Sharp. They seem to just end up flopping the burr back and forth rather than removing it.
In the generally available pocket knife steels, I'd have to rate Queen D2 at the top (if you can sharpen it.... boy did that stuff teach me a few lessons on how to sharpen) GEC's 1095 and 440C pretty high, Buck 420 HC very good, Rough Rider 440A respectable, Case CV, then Vic stainless and Case Tru-Sharp about equal. Now you'd think that me putting Case Tru-Sharp tied for "last" makes it worse, but it's pretty much my daily carry, and I really like it. Good enough for what I need, no fuss, and sharpens back up without a lot of gear.
Kind of like if I could buy a car that does 150 top speed, another that does 120, and a third that does 90. But I'll never exceed 75, so what difference does the top end speed make to me? None. That's Case Tru-Sharp to me. Good enough for me, but I recognize its limitations, which I never exceed.
What work around?I only have a sharpmaker and a strop. That's the thing, the knife is so cheap and other knives work so much better that I don't feel the drive to bother trying to force it to work. I did EDC it for 6 months but a SAK holds its edge far longer, cuts better and doesn't require workarounds when sharpening.
Having to choose a edge angle my sharpmaker can't handle.What work around?
Thank you Sir! I don't live in the US otherwise I'd take you up on it.If you want, I'll reprofile the edge on that for you, to 15 degrees per side. It'll make your Sharpmaker's angles more useful to you.
This is the problem, earlier in the thread it was suggested that 30 inclusive would solve the problem of Trusharp but your experience says otherwise. In the meantime my Sodbuster Jr is probably going to stay in the cupboard.I sharpen my TruSharp at a 40 degree inclusive angle. I tried 30 degrees, but ran into too many edge deformation issues on the very soft steel.
