Casio G-100 G Shock/Surefire G2 Led/Surefire G2X Pro Led (GONE)
jeepin
Feedback: +404 / =0 / -0
I have an excellent near mint condition Casio G Shock model G-100, a like new Surefire G2 Led, and a like new Surefire G2X Pro.
Pm or email me at mashguy4077@yahoo.com with offers.
http://www.casio-usa.com/products/Watches/G-Shock/G100-1BV/
G SHOCK G-100-
Technical Specs
Shock Resistant
200M Water Resistant
Magnetic Resistant*
EL Backlight with Afterglow
Dual Time
Daily Alarm
1/100 Second Stopwatch
Measuring capacity: 23:59'59.99"
Measuring unit: 1/100 second (for the first 60 minutes)
1 second (after 60 minutes)
Measuring mode: Elapsed time
Auto Calendar (pre-programmed until the year 2039)
12/24 Hour Formats
Accuracy +/- 15 seconds per month
Battery CR2016
Approx. battery life: 3 years
Module 2327/5158
http://www.surefire.com/g2x-pro.html
SUREFIRE G2X PRO-
Specifications
Output / Runtime -- White Light
High 320 .0 lumens / 2.5 hours*
Low 15 .0 lumens / 45.0 hours
Tactical Runtime* 2 .5 hours
Length 5 .20 inches
Bezel Diameter 1 .25 inches
Weight w/Batteries 4 .4 ounces
Batteries 2 123A (included)
*Runtime (at highest setting for multiple-output lights) until output drops below 50 lumens
Description
The G2X Pro is a compact yet powerful polymer-body flashlight that uses a high-efficiency LED—virtually immune to failure since there's no filament to burn out or break—to provide two light output levels: a brilliant, penetrating, perfectly pre-focused 320-lumen beam, and a 15-lumen low-output setting that lets you greatly extend the runtime per set of batteries, an invaluable option when you find yourself miles from civilization. Press the tailcap switch for momentary-on low, press further to click constant-on low, return to off and press or click on again within two seconds for high. The tough Nitrolon® polymer body is smoothly sculpted for a comfortable, secure grip and resists scratches, abrasion, and corrosion. A polycarbonate micro-textured reflector delivers a comparatively wider beam with generous peripheral light. We also make an aerospace aluminum-body version of this light, the 6PX Pro, and a single-output version with a tactical tailcap switch, the G2X Tactical.
Features
Virtually indestructible LED emitter regulated to maximize light output and runtime
Two output levels—high for maximum light, low for extended runtime
Precision micro-textured reflector creates smooth, optimized beam
Tough polycarbonate window resists impact
Tough Nitrolon® body, anodized aluminum bezel
Dual-output tailcap click switch—press for momentary-on low, click for constant-on low, return to off then press or click again for high
Weatherproof—O-ring and gasket sealed
Includes high-energy 123A batteries with 10-year shelf life.
SUREFIRE GT LED-
The G2® LED is a compact high-output flashlight featuring a body made of tough, corrosion-proof Nitrolon® polymer and an aluminum bezel. It uses a virtually indestructible power-regulated LED and a precision micro-textured reflector to produce a smooth 120-lumen beam—six times the light of a big two-D-cell flashlight, and more than enough to temporarily blind and disorient an aggressor by impairing his night-adapted vision. The tactically-correct pushbutton tailcap switch provides secure, ergonomic activation control: press for momentary-on, twist for constant-on.
Features
Virtually indestructible LED emitter regulated to maximize output and runtime
Coated tempered window resists impact, maximizes light
Tough, lightweight Nitrolon® body with deep grid pattern for secure grip, aluminum bezel
Tactical tailcap switch—press for momentary-on, twist for constant-on
Weatherproof O-ring and gasket sealing
