Not brand new but I bet you nobody could tell!
This is another one of my favorites! In very good condition,
Casio PAW1100T-7V Pathfinder watch. Titanium, Solar Powered, Atomic time, Compass, altimeter, barometer, Thermometer.
$150 shipped (paypal included)!!
Specs:
•Multi-Band Atomic Timekeeping (US, UK, Germany, Japan)
•Receives time calibration radio signals which keep the displayed time accurate Auto receive function (up to 6 times per day).
•Manual receive function.
•Signal: US WWVB, UK MSF, Germany DCF77, Japan JJY40/JJY60 Frequency: US 60kHz, UK 60kHz, Germany 77.5kHz, Japan 40/60kHz.
•Tough Solar Power.
•Digital Compass: 16 points of measurement Measuring range: 0 to 359 degrees Measuring unit: 1 degree.
•Bearing Memory. Memory Capacity: 1 record (stored direction angle and indicator)
•Altimeter: Measuring range: -700 to 10,000m (-2,300 to 32,800ft) Measuring unit: 5m (20ft).
•Auto memory measurements.
•Altimeter Memory: Memory capacity: 40 records Measurement data: altitude, month, date, time.
•High / Low altitude memory: Cumulative ascent / descent memory Relative altitude display Altitude tendency graph Altitude differential graphic.
•Altitude alarm.
•Barometer: Display range: 260 to 1,100 hPa (7.65 to 32.45 inHg) Display unit: 1 hPa (0.05 inHg) Atmospheric pressure tendency graph Atmospheric pressure differential grapic.
•Thermometer: Display range: -10 to 60 C (14 to 140 F) Display unit: 0.1 C (0.2 F).
•100M Water Resistant.
•Low Temperature Resistant (-10 C / 14 F).
•Full Auto EL Backlight with Afterglow.
•World Time: 29 times zones (30 cities), city code display, daylight saving on/off.
•5 Daily Alarms.
•Countdown Timer: Measuring unit: 1 second Countdown range: 1 minute to 24 hours Countdown Alarm 1/100 second stopwatch Measuring capacity: 23:59'59.99" Measuring modes: Elapsed time, split time, 1st-2nd place times.
•Hourly Time Signal.
•Auto Calendar (pre-programmed until the year 2099).
•12/24 Hour Formats.
•Button operation tone on/off.
•Accuracy: +/-20 seconds per month (with no signal calibration).
•Storage Battery CTL1616.
•Battery Power Indicator.
•Power Saving Function.
•Approx. battery life: 5 months on full charge (without further exposure to light).
•Module 3043.
•Titanium metal bracelet..
•Size of case/total weight: 62.3 X 52.2 X 14.2mm / 118g.
Comes with the Book and Tin can.. for whatever you may need a tin can for with your watch!! Oh and the extra links that I took out so it would fit around my skinny wrist..
volclaedesign@gmail.com
Specs:
•Tough Solar Power.
•Altitude alarm.
•5 Daily Alarms.
•Module 3043.
