Castolite #30 Giveaway - Attention Virginia makers
Stacy E. Apelt - Bladesmith
ilmarinen - MODERATOR
Moderator
A little while back I posted about a crematorium that relined their ovens with Castolite #30, and had about 50 bags of the stuff left over. This stuff is about $80 a bag. It is superb for cast refractory liners and forge floors. You can also cast lids for vertical forges, cast hot work table tops to weld on, etc. He had given me about 15 bags, and they were not sure about what they were going to do with the rest. Today they called me and said to come and get the remaining 30 bags. I don't need that much, but said I would come and get it. I have a friend who will help me transport and store it for the time being. He and I will use maybe 10 bags each in out foreseeable future. That leaves a lot of bags to deal with. I am offering it to anyone who wants a couple bags to use to build a forge or other high temp shop item.
So, if you live in eastern VA, or North Eastern NC, let me know here and by PM or email and I will make arrangements for you to come over and get a bag or two.
I really don't want to haul a lot of this 700 miles, but will take a few bags to Ashokan if a couple makers want to get it there.
Obviously, this is only for someone who will use it, and is on a first come first served basis. I have around 20-25 bags available.
Tip:
Any refractory that you buy should be stored in tightly sealed tubs. The pickle tubs from Firehouse Subs, similar utility buckets from HD/lowes, and drywall/paint buckets are perfect. Just pour in the refractory and seal the lid tight. It will store for many years that way.
Stacy, can I use this over an existing coating? I believe it's Rutlands furnace cement in my forge or should remove it and start over.
Charlie, I don't want to ship this stuff, and I want it to go to folks who will use it on their home forges.
Dopic1, You should be able to put a new floor right over the old one. Castolite isn't the same as satanite, which is used as a coating for refractory wool.
This is for casting refractory sleeves for welding forges and larger forges. The sleeve needs a layer of wool around it to insulate it. The sleeves are usually about 1" thick.
Maybe I wasn't clear enough. I am giving bags of this to anyone who wants to come and pick it up.
If you need it, a couple hour drive is well worth the trip. About $80 a bag retail...plus shipping.
Thanks Stacy, I have a layer of 2" Kaowool in there now, but the furnace cement coating is starting to degrade so I thought I would clean it out and re-line with Castolite. I'l order from Budget Casting Supply not driving to Norfolk. I could order 2 50lb bags with shipping for what that would cost.:)
I think satanite would be far better as a coating over insu-wool. Castolite is a castable refractory.
