When using a gas forge and trying to keep the temp of the steel at a constant (soak), if the temp rises above the required temp, (and forms nasty large grains:
), as the steel cools back to the required temp for the steel of choice, can you pull the blade at that time, (back to small grains) and quench? Or does the steel need to be thermal cycled at this point? Wouldn't the grain size be the same on the way down as it is on the way up?
The reason for the question stems from a lot of readings taken with the pyrometer, and 50-75deg comes and goes very quick. Also the readings are different when the gas is on VS. gas off. Steel in the forge VS. steel right out of the forge. Can't seem to find anything in the text books that addresses this. Thanks guy's!!!!!!
