CATI AR600 Body Armor 10x12 SAPI CQB Multi-Curve, CATI 10x12 SAPI Shape Trauma Pad
Feedback: +228 / =1 / -0
CATI Armor AR600 Body armor 10x12 SAPI CQB multi-curve plates and the 10x12 SAPI shape trauma pads. These plates have there build-up coat applied also. Bought these about 2 weeks ago and I ordered incorrectly. They do not fit the small carrier that is being used, they are too large. These plates fit most medium size carriers. These are brand new straight from the factory. Selling at a loss as I need to re-order the correct size asap.
CATI Armor AR600 Level 3+:
The CATI Armor AR600 armor Ultra High Harness (UHH) exceeds level 3 standards and is special threat tested to the 5.56 round of M193 up to 3100 feet per second.
Trauma pads are manufactured from a specifically designed from a high impact foam specifically formulated for protection from blunt force/high impact trauma. These pads are designed to be worn on the body side of the ballistic plate and serve to provide shock absorption between the armor plate and the human body. We seal each pad with an ultrasonic sewing machine into waterproof rip-stop nylon covering for durability and sanitary reasons. They are very lightweight and are ¼ inch thick.
Build-Up coating is a ¼ inch of the Rhino Linings material applied to the strike face of the armor plate to mitigate splatter. As the projectile passes through the coating and impacts the armor plate the fragments are trapped between the armor plate and the build-up coating layer. The steel plate armor goes through a 4-step process of Blasting, Cleaning, Etching and Priming to achieve proper adhesion of the splatter mitigation coating.
$210 shipped CONUS. Paypal or USPS MO. No trades please. Please PM with any questions, thanks
