It can't take or keep an edge, and it is more flexible than steel.Esav Benyamin said:What "bad things" have you heard?
That's why I have my clear Stinger.Esav Benyamin said:I prefer plastic impact weapons to stabbers, myself.
Overlord said:I BELIEVE they also use the same sheath for all of the different safekeeper models (1-3) regardless of the length of blade.
Overlord in Colorado
bsjoelbs said:That's why I have my clear Stinger.
Thanks that works a lot better than using two hands.Will P. said:Kydex and concealex sheaths are supposed to be tight. Grip the knife with your fingers and push the sheath with your thumb - the knife should pop right out. It take a bit of getting used to, but a tight sheath is critical for inverted carry.
Andre said:The CBK is the newish BM push dagger, right? I f that is the case then I checked one out and I didn't think it felt as good in the hand as the Safekeeper. I have the smaller number 3 model which is very secure in the hand. I didn't like the longer no. 2 cause teh extra length gives it a wobbly feeling in my hand. That's my 5c![]()
jbutera said:Your not going to open boxes with a double edged blade!
benchmade products are much better as far as fit finish and quality. the cbk has 440c heat treated steel and an excellent sheath for not much more money. the cbk has a quality finish too.
