- Nov 16, 2002
I think LVC hit the nail on the head.
For me, they're just cool looking.
the stock satin jack takes 400lbs of force to get it to start bending, and takes a set at 900lbs. The corrugated satin jack takes 500lbs of force to bend, and 850lbs of force to take a set.
Its not stronger, it's actually weaker at the extreme end - but it's "stiffer". it takes more force to make it bend, but not more to make it fail.
You just answered your own question right there "Its stiffer than a skinny barrel of the same weight"
When Jerry introduced the CBT technology he used the cardboard analogy. Corrugated cardboard is stiffer than flat cardboard of the same weight. With CBT's you get a stronger lighter blade than its non CBT cousin.
A side effect of the CBT's is a smaller contact area so the blade will not get stuck in the material as easily. When I baton hard wood this effect is dramatic, my non CBT chopper gets stuck very easily, my Fusion Battle Mistress hasn't been stuck yet.
Why wouldn't it just bend in the thinner area between the milled grooves? They are thinner than the full thickness blade was, thus taking less force.
What it we take this example to an extreme, and mill the areas between the corrugations to 0.003 thickness? Would it be stiffer still?If removing a little material makes it a little stiffer then why doesn't removing more make it more stiff?
If you argue that taking it to the extreme isn't valid then don't you have to argue that there's some sort of 'break even' point where it stops getting stiffer and starts getting weaker? How would that happen?
Reason is, they change the directions of the force vectors going through the material. So, say lateral force is applied, on a standard blade, the force vectors are all aligned. With the CBTs, particularly those on the CGFBM, will change the directions of the force vectors as they cross the CBT, basically enabling the metal to take the force in many directions instead of all in a single direction.
so let's just drink the physics away
