Center line scribing
I have seen a nifty tool used in several shops and feel like an idiot asking what it is called.
it is a flat piece of stone with a micrometer (?) with a scribe on top of it that allows one to scribe a centerline on a knife in process. What is the terminology for this equipment, and where can I find one?
you may be thinking of a dial height gage
3250Z-6ecUSp1
I was shown to take a drill bit that is slightly smaller than the stock thickness, c clamp the drill bit to a surface such as a drill press worktable, then slide the edge end of the blank into the tip of the drill bit. I hope that makes sense and hopefully it helps.
Grizzly has them for the best price I could find. $43. There made in China, but work just fine.... Definately worth the money.
Erik, I have one of those that was given to me. It is not the one from Riverside, but works the same way. It does a good job at keeping the lines in the middle but it won't work towards the tip as the guide rod closest to the tip comes off the blade before the scribe makes it all the way.
Just be sure to flip it to scribe both sides.
Jason
I hate to say it but go to Enco and get a 6" import height gage.Then find a local granite counter top shop.Bring some beer and get a sink cut out for a surface plate.
Rick
When height gauge is not available I've used a variation of s2f's. To create parallel lines .030" apart, use an old drill bit .030" thicker (or thinner) than the stock being used. Grind a sharp central point on the bit. Hold the stock flat on the surface plate, lay the bit on the plate and drag the point along the edge of the stock, flip the stock over, and repeat.
