- Jan 31, 2014
One thing I noticed is that a sharpie works better than dykem. The blue dykem discolors when it gets hot. The Sharpie stays pretty much unfazed. I just use calipers to scribe the lines.
A height gauge and a granite surface plate is the best way to do it.
There's no way a drill bit is going to give you a line that is as deep and easy to see as a carbide tipped gauge.
All the gizmos and calipers don't account for blade warp. They will follow along the edge of a boomerang and put a line in the center of it. A height gauge and surface plate won't hide anything.![]()
I used the drill bit method until I picked up this little guy. I think I got it from USA knife maker, I'm not 100% though. Works pretty good on stock up to 1/4"
I've had many, but the latest is a 02 Fat Boy.Simple - I wondered if that's how you did it, but didn't think that would be precise enough. Now I see your dwg, I can see it'd work great. I do think that just might work better than anything else. I'll make one of those in a few days. VERY simple to make.
Mr biker - THANK YOU for the quick response. What do you ride? I'm an old reformed hog rider who's now on a GW.
Ken
Am I going to get my pee-pee slapped for admitting that I don't scribe centerlines on any of my blades? I have never had an issue with uneven grinds. Perhaps I'm just lucky. You'd probably throw up in your mouth a little if you saw me grind a blade, Ha!
I made a scribe like the one shown and found that one post will fall off the blade before you have scribed the entire length of the blade. You lose the distance from the center scribe to one of the guide posts. I've started using a height gauge on a granite block as Mr. Wheeler has suggested. This works the best of all the methods I've tried.
I understand the precision needed for a folder maker working with PG O-1, but a surface plate, height gauge, and carbide scribe tip is a lot to spend (and takes a bit of time to set up and put away), when all most folks need is 60 seconds at the grinder.
I have at least six different scribing tools, Most are carbide and very precise, and some were expensive. Unfortunately the blades most knifemakers profile are rarely precise, dead flat, or evenly thick ( consider a hand forged blank). A straight 45 degree edge down the center will allow grinding without any risk of the bevels being uneven.
