- May 22, 2002
Which center scribe is good?
Where do you get them ?
If there is a woodcrafter's store close you can get the granite surface plate there and skip the shipping.
Stan
Stan
I have used drill bits for a very long time.
Surface plates also come in handy for sanding flats to get then truly flat.
--nathan
thats the easy part, Grinding up to the lines across the entire length of the knife is the hard part. Great advice Michael.A surface height gauge allows me to mark two "grind to" lines from the same side of the blade. After surface grinding, I mic the thickness, then lay the blank on the surface plate and tap it on the ends with my finger. I do this from both sides. If it isn't perfectly flat, it will rock from one of the sides. If there is any rock, I tape down the handle end with the point "sticking up" (this may only be a couple thousandths, but still enough to merit correcting.) I then calculate my center distance, and further calulate a "plus .010" and "minus .010" value, as I grind to 20thou before HT. I then mark my blade to the plus/minus lines by changing the guage, not flipping the blade over. This provides not only nice, parallel lines, but a blade centered with the handle.
If there is any warp, flipping the blade over will result in non-parallel lines,(and possibly non-centered lines), and your edge thickness will not be consistent when you grind to the lines. This overcomes that inaccuracy.
It also overcomes the inaccuracy of running a caliper down down either side of the knife. That will scribe parallel lines, but they may not necessarily be straight and will follow any curvature in the blank.
