- Nov 23, 2012
Can it be done? Either at home or by sending it out to CRK. Any one who has either tried or knows feel free to chime in
It is a misconception to say that re-assembling the knife will always fix blade centering. Many CRK leave the factory with off-center blades that have nothing to do with the assembly or pinched washers. Perfectly centered blades is not something that CRK guarantees, or provides 100% of the time. Typically one wont leave the shop with the blade rubbing the scale, but they are not all dead-center. Many are, but not all.
So the question is, if the blade has a bow in it, can that be solved or corrected? I would like to know as well. I have a large Insingo, with less than perfect centering, and a small 21 with similar traits. Neither knife bothers me as they are users, but I would like to know if CRK could make them perfect. In both cases the blade is just ever-so-slightly warped.
Can a heat-treated blade be bent back true?
It's typically not worth the time to try and correct the bowing from my experience with other parts..Blade replacement I think would be the best option for the true nit-picker.
Blade centering can be a function of the washers being thinner than the rear spacer as well. Think about stacking the washers and blade, then measure that and compare it with the measurement from the rear spacer. If someone lapped the washer to make it smoother and was somewhat aggressive about it, then blade centering would be an issue..Of course, if the blade is ever so slightly bent, then this would magnify this effect.
Good info, thank you. I have never been that bothered by it. They were like that from new, so I guess I assumed the washer stack would be the same height as the backspacer. Now that you have mentioned it, I will get out a caliper and check.
Thanks!
I guess I still have the question of whether a heat-treated blade can be bent, or if it would just fracture if you tried. I think I recall that in the Blade HQ vids Chris talks about the blades getting warped by heat treat and having some jig to straighten them. That is likely before the grind mind you.
Just thought I'd mention...I just requested a "price list" for spa treatments, and it looks like you can no longer purchase new blades for a regular. Can anyone confirm or deny this?
The thought that I can't replace a regular blade makes me hesitant to use it in a "less than gently" fashion.
It's possible to straighten a blade..There is a risk of breakage as lateral stress is applied. I guess it's much easier to say that steel is not glass and can withstand some stress. It would be fun for me to play with and try to figure it out on a knife, but it's also likely to be variable from knife-to-knife.
I love CR Knives and the company is beyond reproach.
That said, am I to understand that if anything happened to the blade on my large regular Sebenza that I am SOL? That I would have a couple of Ti slabs and no chance of making it a knife again???
I think the biggest culprit of blade centering is that the grind on the knife is slightly off-center. The blade stock might be dead even compared to each scale, but the tip of the blade can be ever so slightly closer to one side.
Just last month I sent in a lg reg. BG-42 serrated to CRK. A small crack and started in one of the serrations. It is true they do not have any BG-42 Reg blades but they did replace it with a new S30V Rg. blade. So they do have Lg. Reg. Blades just not in BG-42.
