I haven't read the article, but this knife is no weapon. Firstly, Spyderco isn't a company that makes weapons - with one special exception, geared towards defense. Secondly, the knife has no guard to prevent your hand slipping onto the blade and very little belly to slash with. Like the Benchmade Spike, it would make a decent shank but a lousy fighter - but I'm sure that wasn't Spyderco or Mr. Centofante's intent. Also, the small hole partly covered by the back scale precludes the rapid "drop" opening method, despite the clip orientation.
I've frequently heard folks say this knife "cuts like a laser." It's blade grind isn't well-suited for heavy duty, especially in a relatively brittle steel like ATS-34, but it is ideal for more "gentlemanly" tasks. Spyderco has said that the knife
may be released in 440V.
Compared to the Viele:
I think both have grips that make thrusting unwise but are fine for utility. Both have small holes and are unwise to open with the "drop," though carried tip-down. The Centofante is in a better steel in terms of edge-holding, but the Viele blade is probably slightly more robust. I don't know which size Centofante you are looking at, but the Viele may be heavier than either - I can't find its weight listed, but it's quite beefy. The Viele is one classy knife, very attractive and suitable for dressing up. I personally find rough G-10 very utilitarian, but the Centofantes almost make it look good. I think the SecureLock is a moot point, because Spydercos are well-fitted and won't close on you without it.
Its a tough call. Either one's a fine knife. I'd get a Centofante, but that's only because I've spent a lot more time with Vieles and always lean towards the less familiar knife
-Corduroy
(Why else would a bear want a pocket?)
