Cerama-Coat NIB
Feedback: +75 / =1 / -0
SOLD to Fishface5
Just got this last week but decided to do an etched finish instead. Nothing wrong with it just thought someone else could use it.
Never used in original box etc, will post pics if you want.
Find it at Midwayusa under the spray finishes.
Here is what the website says:
Instructions
Wheeler Engineering Cerama-Coat Instructions (PDF)Easy to use aerosol coating can be applied to practically all metal surfaces. Fine ceramic particles provide strength, durability, and lubricity. The result is a matte black finish that stands up to moisture, solvents, and wear while protecting against rust and oxidation. 4 oz. can contains enough Cerama-Coat to finish two long guns or several handguns. Not for use on wood, plastics, or scopes.
Technical Information
Notes:
Spray-on metal finish
Matte black color
Can contains enough coating to refinish two long guns
Not for use on wood, plastics or scopes
Instructions:
Degrease the metal to be coated, shake Cerama-Coat can and spray surface with three light coats of finish. Bake the part in an oven at 350 degrees for 30minutes to cure the finish.
$25 shipped Parcel Post mail if you use PP, PM me and I will send the acct info.
No fees
I'll take it, I was just wondering how to re-finish my 1911 frame on the cheap, so sick of lame cold-bluing . . ..
