I wonder if you could get them from a pottery or ceramic supply house?
The word 'ceramic' really just means made from non-metallic minerals... like clay. There are all different types of 'ceramics,' ranging from 'Play-Doh' to the heat shields used on Space Shuttles. The stuff you'll probably find in a pottery supply house will be in 'raw' form. To be usable as bowls, jugs, electric line insulators, space shuttle heat shields, and sharpening rods, they need to be made from use-specific material and then baked at a specified temperature for a specific period of time.
If you are looking for really effective ceramic hones (without looking in knife sharpening supply houses) go out in the desert and find some of the old electric insulators, or pieces there of. Pieces are easier to find as folks have been shooting at those things for the past 50 years, since the high electric power lines were installed instead of the low power poles along side the roads. Those old insulators are fantastic sharpeners! If you ask a local electric line worker, they can tell you were to find them easily.
Next bet would be flea markets and swap meets, looking for old thick crock pots. The bottoms usually are not glazed, and that also works like a charm! Buy the broken ones for 10 cents... you don't need it to hold water. You're going to use it upside down anyway!
Last on the list are the OLD mugs you used to find in dinners. Really thick, heavy mugs. The older the better. At flea markets, look for ones with really crazed and cracked glaze. Again, it's the unglazed bottom that you want to use on those.
And for those who prefer a guided system, pick up an one gallon pickle crock. Lay your knife flat against the inside curve and just rub it around the circumference! Be sure to go in both directions to get both sides. The natural curvature of the crock will give you just enough of an angle to touch up your blade. The narrower the crock, the steeper the angle. Flea markets and yard sales are great for finding these too!
Stitchawl
