Would an eraser be fine for a lansky ceramic rod?Assuming you're talking about the Spyderco rods ...
I use a pencil eraser and clean them after every dozen or so strokes of the knife. Takes about 10 seconds to get most of the metal off.
Every now and then I'll use one of those Scotchbrite plastic scourers with warm water.
Keeps 'em working just fine.
How do you guys clean ceramic rods and how often do you clean them?
Soap-impregnated steel wool (+ water) has worked best for me. I don't know what brands there might be in different parts of the world, but you should find it at the cleaning supplies isle in most supermarkets. I try to clean my rods after every time I use them, but quite often it seems to be more like after every second or third use...
Yep ... an inexpensive ink eraser you can buy almost anywhere works very well.Would an eraser be fine for a lansky ceramic rod?
I wondered about that, too, at first, but it works just fine. My guess is that the lubricating qualities of the soap and water and the fact that the steel wool's strands are so flexible is what prevents the steel wool itself from leaving metal on the rod.Steel to remove steel??? Since the ceramics are designed to abrade metal, it seems to me that using steel wool as a scrubber might be somewhat counterproductive.
Way-O--- Steel to remove steel??? Since the ceramics are designed to abrade metal, it seems to me that using steel wool as a scrubber might be somewhat counterproductive.
