Found this while digging through another forum for research into one of my lame ideas. thought you may be interested in it. http://moleculepolishing.wordpress.com/2013/08/08/the-mystery-of-the-spyderco-and-the-wicked-edge-ceramic-stones/
That was cool!
I have been thinking about getting a set of the Spyderco (M, F, UF) ceramic benchstones. If I did, would I need to work them like the guy on that blog?
I was reading the article in a hurry before I left for work and I thought the author was implying that the stones needed to be lapped before use.
Off topic: Knifenut, do you recommend the Spyderco ceramic bench stones that come in blue boxes?
The "saw marks" on a spyderco ceramic are from them lapping the stone. The fine stone is lapped to a UF stone.
I've seen a picture of the machine, it looks like a oversized floor buffer with several grinding heads that spin on a larger spinning plate. Think industrial size equipment.
It would not be efficient for them to cut stones from a large block, the ceramic would be hell on the cutting bit. I'm pretty sure spyderco fully admits to simply lapping the fine ceramic to make a UF ceramic.
Also, sandpaper will be completely ineffective.
Can't you just scrub the thing with diamond paste?Why would you want to mess up a perfectly fine stone?
Besides that you would need a set of diamond stones that would get ruined in the process. I've messed around with lapping spyderco ceramics and the result is never as good as the new stone.
I'd be interested in finding out if you could get an UF stone to sub-micron fineness like 0.25 micron. And I'm rather curious about why the ceramics would ruin a diamond stone if the diamonds can typically handle ceramic knives with no problem and are in fact designed for exactly that.
