CF knife is sold, thanks. Two knives in this thread, the other is still available.
I wanted to do something a little different so I settled on a modified tanto style blade with secondary grinds for this build. Lock up is bank vault tight with no movement in any direction. Lock up is about 40% and the hardened carbonized lock bar disengages easily. The action on this knife is super smooth with caged bearings riding on precision hardened stainless washers. The bearings have no contact with the titanium which improves smoothness and durability. The knife is nice and slim with only .015 clearance around the .156 cpm154 blade. Here are this specs:
Modified Tanto Titanium Flipper
Steel- .156 cpm154
Closed- 4 3/4 inches
Open- 8 1/4 inches
Blade- 3 3/8 inches
Grind- Flat ground with secondary tanto grind drawn swedge and jimping on spine
HT- In house with dry ice cryo to a tested 60-61rc
Finish- Stone washed
Frame- .140 Titanium on lock side and .070 titanium on presentation side with checkerboard carbon fiber scale
Pivot- 3/16 hardened stainless steel with caged bearings riding on stainless steel precision washers. Bearings do not contact the titanium
Detent- 3/32 stainless detent for a nice smooth positive detent
Backspacer- Black G10
Clip- machined titanium clip set up for right hand tip up carry
Hardware- Stainless steel
Asking 325.00 SOLDshipped in the USA
Paypal, USPS M/O or Certified check preferred
Questions or comments welcomed
Thanks for looking
Switchback Flipper shown below[ is SOLD
Tactical style flipper with centered blade, solid precision early lock up, with no movement in any direction This one flips hard and fast with stainless caged bearings riding on hardened steel washers Here are the specs:
Closed- 4 1/2 inches
Open- 8 inches
Blade- 3 1/2 inches
Steel- CPM154 x 5/32
Grind- flat ground with drawn swedge and jimping
Finish- Hand sanded, bead blasted, and stone washed
Frame- .140 titanium with jimping and machine work
Finish- Sanded, bead blasted, stone washed and anodized
Clip- Machined titanium set up for right hand tip up carry.
Pivot- 3/16 stainless with stainless caged bearings and hardened steel washers
Back spacer- Black G10
Asking 325.00 shipped in the USA
Paypal, USPS M/O, or Certified check pre4ferred
Thanks for looking
Steel- .156 cpm154
Open- 8 1/4 inches
Blade- 3 3/8 inches
Thanks for looking
Open- 8 inches
Blade- 3 1/2 inches
Thanks for looking
