- May 19, 2007
half a rusty soup can full of bear-fat, just like the inuit do. Or there is some stuff that comes in a blue and yellow tin thats expedition grade wind-burn guard.
Bag Balm. Yeah, it smells like a machine shop, but it sure works. Anything that is made for cow udders has to be good, right?
But ARKnives, I love the Chapstick Man Project. The heat shrink idea is pretty good too - as long as you don't melt the Chapstick in the process.
I think the use it/need it theory of lip balm is a myth. The exception to that is Carmex. It is nominally for cold sores and contains salicylic acid. Salicylic acid dries up sores. So Carmex contains both moisturizing and drying ingredients and works at cross-purposes when applied for moisture.
Chapstick, Blistex, Burt's Bees are only moisturizers, mostly petrolatum, ie Vaseline.
A .410 shotgun shell casing.
I just carry around a jar of Vaseline - you should see the looks I get!
And it helps start fires, too!
You can get Burt's Bees in a tin.
http://www.burtsbees.com/Beeswax-Li...d.html?cgid=beeswaxLipBalm&start=4&q=#start=4
I've always preferred a tin to a stick, as far as lip balm goes. No matter what kind of case you fashion for a stick, it's still gonna look a little bit like you're puttin' on lipstick... maybe that's what your buddies chuckle about. The tin is where it's at, IMHO.
Try one of these, it's exactly what you're talking about!
http://www.sunshineproductsusa.com/index.cfm/d-Fancy_Chapstick_Cover_42.htm#.Uw1tgGt5mK0
