Char Cloth Recipes
Great post. You learn something every day. I will have to make some of this for my next scout meeting. The scouts failed miserably on their first "survival" fire building attempts.
Also, Vaseline cotton balls seems self explanatory, but indulge me. take some cotton balls, and add some Vaseline????
There may be better ways, but I just smear a cotton ball or pad around in a bottle of vasaline so it picks up "enough." Maybe 1/4 tsp. per ball. When I take a ball out of the 35mm can, I fluff it up with a small stick (or match) before lighting.
Yeah, for vaseline/cotton balls you don't want to saturate them all the way through. Coat the entire outside and work it in just a little bit.
When you want to light one you tear it open so that alot of the dry interior is exposed - this is what catches the spark and then acts like a wick - drawing up the petroleum and allowing it to burn. Essentially it's a mini oil lamp.
It still works when the ball is totally saturated, but then it requires alot greater heat source to obtain ignition.
For char cloth I prefer denim and my 'secret' is to stuff a cannister with scraps of cloth, close it up, poke a hole in it, then drop the whole thing into a bed of coals. When smoke starts coming out of the hole light the smoke so that it becomes a flame. When that flame goes out remove the cannister from the coals because it's done. Cannister with a large surface area to volume type of shape seem to work best.
