Charge Ti vs. Swisstool observations
After hearing a lot of opinions on both I decided to sit down with a notebook, a pen, a caliper, both tools, a can, and a wood block. I compared the features of both and ended up with five written pages of observations and comparisons. Here is what I observed: ("L" refers to the Charge, "S" refers to the Swiss tool)
Weight:
S: Feels slightly heavier
Weight feels very close.
Size:
S: Longer (Taller), Wider
L: Thicker
Handles:
L: More Grip, Feels more positive
S: More flex when squeezed together
L: More flex when side scales squeezed together
L: Wider, Thicker
S: Longer
S: Steel handle scales
L: Titanium handle scales
Opening of handles:
S: Harder to open
S: Difficult to open and close one handed without assist of leg, side, ect.
S: One stop while opening (90*)
L: Can be opened and closed one handed
L: One stop while opening (greater then 90*)
L: Has kind of a V opening channel to keep pivots from becoming loose. (No more butterfly knife tricks)
Pliers:
S: Held into handles by pins (non adjustable)
S: Regular nose style
S: More steel around pivot pin at bottom/top
S: Large teeth grip better
S: Thicker at base
S: Better grip at tip
L: Held into handles by pivot screws (non user adjustable)
L: Needle nose style
L: Bigger Pivot pin
L: More steel around pivot pin on sides
L: Larger wire cutter
L: Spot to cut thicker wire without damage
L: Small teeth grip better
L: Wider at base
L: Opens wider
L: More small teeth in contact with object being gripped
Ruler:
S: Longer
S: Holding pliers head closed keeps it from folding
L: Used to aid in handle grip
L: Designed to not fold when pushed against object being measured
Both accurate
Carry options:
L: Pocket clip* (easily removable), Sheath, in pocket, and Lanyard (both built in hole and removable hole, paracord fits)
S: Sheath, In pocket
Both fit well in jeans watch pocket
*Pocket clip has a side to side movement of about 3 mm
Tool locks:
S: Near impossible to open tools one handed
S: Dead bolt style lock (similar to axis it seems) with back spring like a slipjoint to create a stop/snap open
S: Very difficult to identify tools blind
L: four main tools use liner lock, aux. tools use a lever style lock
L: Difficult to open inner tools one handed
L: Tools can be identified blind
L: Lock spring looks like it will last longer (comparing L: Lever lock to S: sliding lock)
L: Easier to work one handed (comparing L: Lever lock to S: sliding lock)
L: More thumb purchase (comparing L: Lever lock to S: sliding lock)
L: More thumb grip (comparing L: Lever lock to S: sliding lock)
Both locks can be worked one handed (comparing L: Lever lock to S: sliding lock)
L: Definite advantage with the liner lock (on 4 main tools)
L: Tools on average lock up tighter (especially tools using liner lock)
Tool/Implement selection (L):
1. Can opener
2. Wire stripper (triangle style) (on can opener)
3. Large Bit driver (with spring to hold bit in)
4. Large/Medium-Large screwdriver
5. very small screwdrivers in small bit driver (both standard and philips) (held in by compression)
6. Scissors
7. Build in lanyard hole
8. Knife (one handed opening) (clip point)
9. File (crosscut on one side) (diamond dust on other) (hacksaw part)
10. Serrated blade (one handed opening) (no stabbing point, but not completely blunt)
11. Opposing teeth saw (angled teeth)
Tool/Implement selection (S):
1. Regular SAK style blade
2. very large screwdriver
3. Wood Chisel
4. Wire stripper (Triangle and round) (on chisel)
5. Bottle opener
6. Medium screwdriver (on bottle opener)
7. Can opener (with small screwdriver)
8. Opposing teeth saw (straight teeth)
9. Full Serrated SAK style blade
10. awl
11. philips screwdriver
12. file (crosscut style on both sides) (hacksaw teeth)
Tool/Implement observations:
S: Most tools are too polished to get a good grip
S: File hacksaw teeth farther apart
S: File thinner
S: saw cuts equally on push and pull
S: saw thicker
S: no real lanyard hole
S: corkscrew attachment available
S: longer screwdrivers on average
S: 440A steel or its equal used throughout
L: Bits in large driver get an excellent grip (the allen bits are some of the best I ever used)
L: Better can opener, the S's can opener would not work on a few cans
L: Scissors can slip off spring of cutting under certain side pressure
L: File hacksaw teeth closer together
L: File Thicker
L: Less file flex
L: Saw works faster
L: saw cuts more on pull then on push
L: saw thinner
L: tiny screwdriver gets stuck if pushed to hard while using philips side
L: no real awl
L: short screwdrivers
L: 400 series stainless steel, 154cm steel main blade, S2 steel bits
L: bronze bushings on 4 main tools
L: When the pliers are open the main blade and serrated blade are locked closed (nice touch)
Both have optional bit drivers
Final observations/comments/opinions:
For my uses I prefer the Leatherman Charge Ti, and see it as the better tool. I find it easier to carry, the one handed opening blade of 154cm held by a liner lock means I can carry it as my only folding knife and feel comfortable, the ability to open things one handed I find very important, the needle nose is a must, and the lanyard hole is a must. The ability to change to allen bits and torx (which I use often) is a big plus. However, the two big things I like about the Swisstool are the longer screwdrivers and the awl.
For me the swiss tool is too polished, the polished outside is annoying because it shows scratches like crazy and I constantly find myself wiping fingerprints off (Not really important, but it is annoying). The polished screwdrivers slip easily, which is very annoying (and could be dangerous). The lack of a real lanyard hole is very sad too, I find a lanyard to be extremely useful working up high or out in the woods.
One thing people often say about the Swiss tool vs. charge is the selection of tools, while the Swiss tool has more the only tool the Swisstool has that the charge doesn't that I find useful is the awl. The chisel and bottle opener (especially when there is already a can opener) I don't really find that useful for the amount of space they take up. I think the charge makes better use of space. If Victorinox would trade the chisel and bottle opener for scissors it would have probably the best selection of tools out there. As it is now I see it as being better then the Supertool 200, but not as good as the Charge.
Well, those are my observations and opinions. My only qualifications are I am user and collector of multitools (owning roughly 30). Therefore, take what I have written for as much as you think it is worth.
oh very gd job,shpshooter!
now i want to know about the diffence btn. swiss tool and swiss tool spirit too! ;)
Great comparison!
Have you checked out the SwissTool X and SwissTool RS? Both offer scissors. My favorite version is the SwissTool X.
--Bob Q
Thanks shpshooter. You are right about blind tool selection on the Swiss Tool. Having used mine daily for 4 years you tend to just forget about this and get into the unconscious habit of rapidly flipping it over when you find yourself having selected the straight blade instead of the serrated etc.
However one thing you did not mention is physical tool extraction. I am personally find the ST/SAK design with a thumbnail grip on the edge of the tool superior to the LM design with the grip on the base of the tool. The physics of applying leverage are simply better in the ST/SAK design being farther away from the pivot point.
I've only ever carried my ST on my belt, so have never given a thought to size/weight. If I had to carry it in a pocket a Charge or Wave would definitely be superior, although I would be concerned with how easily the main blade can move out of the tool to expose the point. Does the LM clip design hold the Charge blade up or blade down in the pocket?
As for the general tool selection, have you seen the socket set for the ST that is available? It is standard on the RS version and can be purchased as an add-on (Ebay seems the best source) for the basic ST models. Like the Charge comes with a belt pouch that fits both the socket set and the main tool. Seems like this adds the same functionality as the Charge with the advantage of taking standard tool bits instead of a proprietary LM design.
As for tool choices none of the current ST version (Including the Spirit) is quite perfect for me, as I'd really like to have one that has a straight blade with a spearpoint, a serrated blade with a sheepsfoot, the saw blade, the file AND the scissors. I could live without the very large flat screwdriver in all the ST models. However although the ST is not quit perfect, I can live with it with the addition of a LM Micra on my keychain. However I could not live with the Charge without a decent Awl, I use this all the time. (I guess I could get a small SAK model with an Awl to supplement a Charge, but this would not be locking.)
So for me I'm sticking with my ST until the next major design revs from LM and Victrinox.
AuntyDan - I have seen the add on tools for the Swisstool, but I didn't think that attach to the tool but that it is a seperate tool to be used without the Swisstool. Do I have that wrong?
J
nice comparison shpshooter, i was already interested in the Charge to replace my Wave and i think it's quite a good tool.
i have one important issue that i'm curious about on the Charge though: how's the clip? is it actually useful to use it and clip it to your pocket, as you would do wil, like a Spyderco? or is there still quite a chance that the Charge will fall out of the pants-pocket easily because of the significant weight of the tool? and does the clip have enough "clamping" tension to make it useful, or is it rather loosy?
hope to hear soon.
denn
hope to hear soon.
denn
Ive had the charge for about a month now and i have found the pocket clip to be very strong and secure and cant really fault it .I like the idea of the quick release and not having to undo any screws to remove it .The Charge has just about now replaced my edc supertool or swisstool , give me another couple of weeks and i will be sure .One thing is certain though is the extra bit kit ,i got mine the other day and it really opens up the changable bit holder.
dunc
Well done shpshooter a very good comparison , i have both a charge and swisstool (and a supertool 200 ) and share many of your comments .Please feel free to ask me anything i can share on here about the two . Ive owned a standard swisstool for 5 years and a charge for a month . Once again well done for a good post .
Dunc
Bob,
Yes, I have used both. The X and the original are my favorites. I really can't figure out which I would carry more, I think I use the scissors and serrated blade equally as much, so I wouldn't know which to get rid of. However, I have a Leatherman squirt S4 or SAK Classic SD close by usually so I think I would carry the original more.
dennis75,
I find the pocket clip to work very well. I like how it is detachable to I can bend it a bit to adjust it to my liking (be it looser or tighter). It does hold very well for something of that size. It creates friction between the textured handle scales and the pocket, which helps it to hold tight.
AuntyDan,
The clip is set up for right handed tip up carry only. For safety tip down may have been better, but for EDC I prefer tip up, so I guess it tailors more to my liking then to my safety. :D
I have seen to tool kit and have been meaning to purchase one, that and the corkscrew attachment. I still can't figure out exactly how the corkscrew attaches from pictures.
shpshooter said:
Bob,
What a great opportunity to buy another multitool! The SwissTool RS has both the serrated blade AND the scissors!
J
J
However, no file, which I use more then the scissors and serrated blade combined. You know, if a company would listen to what us knife/tool fanatics want in a multi-tool they could sell a million. So far I haven't seen one that really comes close.
I mean, if they would start just by putting these implements into one pliers tool they would be way ahead of every other company:
1. One handed opening Knife (154cm or better steel)
2. one handed opening Blunt serrated blade (easily identifiable from regular blade)
3. File with hacksaw side and diamond dust side that could be removed to sharpen the main blade
4. good saw (always liked Gerbers jig saw blade holder)
5. can opener
6. awl
7. scissors
8. long small/med/large screwdrivers
9. long philips driver
10. corkscrew (with the SAK removable mini screwdriver for glasses)
11. pen
12. pocket clip
13. Lanyard hole (big enough for paracord)
Victorinox and Leatherman could do it do easily, but they wont, because they know if they made something that good they wouldn't be able to sell anything else.
I'd love to loose the large srewdriver and the file on the swiss tool in place of a pair of scissors. Much as I like the swiss tool I think the file is utter crap
whats the price difference between the LM and the swiss tool in the US. I got the swiss tool for £23 unwanted gift but a LM would have been about £55 so out of my price range
shpshooter, the corkscrew attaches to a slotted hole on the hinge covers of the pliers (The pliers need to closed for this.) This was a new design, the original SwissTool models just had a plain round hole (Theoretically for a lanyard) in that position so the corkscrew cannot be added to an older model tool.
I have never actually seen the socket set for the Plus/RS model in the flesh so do not know how/if it attaches, if so I'd assume one end goes over the fixed Philips driver.
I disagree with Andy_L, for my uses the file is great.
Hmm, that is why it wouldn't work on mine. Mine is the old style.
Anyway, my Charge I paid $66 and the Swisstool I paid I think $80 when it first came out.
Victorinox Swiss Army SwissTool Spirit with Leather Pouch and Swiss Army/Victorinox Hat is currently ( 1/1/2005) $48.79 at Amazon.com.
However the Victorinox Swiss Army SwissTool RS is $59.88.
Andrew J. Gnoza, III
Explosive Safety & HazMat Consultant
Explosive Ordnance Disposal Consultant
Hazardous Materials Consultant / Instructor
Weapons of Mass Destruction Instructor
Very good job. I think your comparison is THE way people have to do when they want to test everything.
One question, as you own a lot of multi-tools, what about a tool with a HAMMER ? Do you know some ? What the difference in comparison against a Swiss or Leatherman ?
Thanks
Where did you get a Charge for 66 dollars :eek:? Most places I see them at are selling them for 99 dollars. At this site: http://www.all-leatherman-4-less.com.... they claim to offer the lowest price guarantee "If you find the same product on the net for less, we'll beat that price by 5%. If you find it for less after shopping at All-Leatherman-Tools-4-Less.com,
let us know and we'll refund the difference." On that site its going for 99.90 and I don't think I've run across any other website offering it cheaper than that. I think I'd buy one if I could find one new for that price :D .
Nope, I bought it from a local Galyans store as soon as they came of the truck for the first time. A combonation of a managers discount sticker and I'm thinking the wrong price in the computer (another Leatherman perhaps?) means I only paid $66.00 with tax. Best price I ever paid for a multitool, well, except for the free Wave I got from Tim Leatherman himself, but that is a different story.
A google froogle search gives me $83 as the best price for an xti.
N2
