- Sep 15, 1999
Another vote for 'Zaan
For a less expensive alternative I'd choose a Spyderco Military
Alright knife dudes, I’ve been interested in getting peoples opinions on a VS. The Chaves Ultramar Redencion 229 Tanto full Ti VS the Chris Reeve Umnumzaan Tanto.
What would you choose & why?
What knife do you think will be more reliable in the long run when it comes to hard use?
What knife do you think will ultimately last longer and why?
It’s crazy that it’s been almost 2 years since I’ve been back through this thread but when I posted this originally, I already owned about 18-20 Chaves knives.What did you end up getting and what do you think since this thread has already meen Necro'd
Neither, ZT0640 is the wayAlright knife dudes, I’ve been interested in getting peoples opinions on a VS. The Chaves Ultramar Redencion 229 Tanto full Ti VS the Chris Reeve Umnumzaan Tanto.
Nice, had my 0640 since I want to say 2020. It was only carried and used for maybe a month. The knife scales are extremely slick and when using it, it really does feel like it’s going to slip right out of your hands. Still to this day, it sits in my knife case getting absolutely no love. I try bringing it out from time to time but it goes no further than a couple flicks open and then right back into the case.Neither, ZT0640 is the way
I love my Chaves knives however, I’m not sure of others experiences but Reate’s M390 is ridiculously chippy in the beginning.I like the reduncion 229 but for a user I would pick an Umnumzaan
The handle of the reduncion 229 can be a hot spot on the rear. It is very spicy with an agressive hollow grind which I like but may be fragile for harder use. It runs on bearings, and even if I never had problems with bearing, it can be a concern if you use it in an environment with a lot of thin particules/dust.
On the other hand the umnumzaan has a more comfortable handle (even if I prefer the ergonomics of the inkosi), the hollow grind is very well balanced between cutting performance and robustness.
It runs on washers and the thumb stubs act as blade stops and help to stabilise the blade when their are lateral constraints
And IMO the clip of the umnumzaan is more functional
I’d go Zaan but you mentioned food prep. I’d suggest going for the Drop Point Zaan (even harder to get than the Tanto) if you plan on doing food prep with it.
The Tanto can absolutely do food prep, but to finish your cuts through food youre going to have to mate one of the edges completely with the cutting board. Which can be a bit difficult with how in line the edge of the blade is on the Zaan. Another option would be to do a dragging cut, like you would with a drop point. While this works, you will be making a cut into the cutting board or flat surface while you drag the secondary tip on it.
A drop point variant would just slice like any other kitchen knife.
Outside of food prep, the Tanto is great though. I’d go for the Umnumzaan over the Chaves everytime. Better customer service and warranty, plus life time of spa treatments. Plus, better resale value if you decide to part ways. Also easier to
Both of my 0640s are wearing Micarta scales and are plenty grippyNice, had my 0640 since I want to say 2020. It was only carried and used for maybe a month. The knife scales are extremely slick and when using it, it really does feel like it’s going to slip right out of your hands. Still to this day, it sits in my knife case getting absolutely no love. I try bringing it out from time to time but it goes no further than a couple flicks open and then right back into the case.
I gifted it to my father and he had it for a while but also never used it because of how slick it is.
The only ZT I kept in my collection that I actually like is the 0620cf.
I’ve done this with one of my Redencions. In my opinion, the detent is far too strong for washers.For those saying washers vs bearings; on almost all Chavez knives from reate you can replace the bearings with thick washers, I do this![]()
If money is no object, then sure. I've had a couple of Zaans, I just don't get the hype so they both ended up moving to new homes. For me a tanto Inkosi is the sweet spot CRKAah I misread. I thought you said you had one on the way.
I haven’t tried micarta scales with it but for me, I’d still choose an Umnumzaan.. probably over any ZT.
