Take an air compressor and remove the airfilter. This is usually about a 1" pie thread atatchment.
with plumbing fittings reduce the 1"? NPT (national pipe thread) fitting to acept a 3/8" hosebarb.
Attach a hose to this(about 3' should do it)
Take a 8" stainless steel canister (kitchen flour/tea/sugar canister 9$ at a harware store,I used one that has a plexiglass lid and has a rubber gasket on it with a hasp to keep the lid shut(like on a grolsh beer bottle) gluethe gasket down to the lid with silicone) drill a 1/4" hole in the bottom of the canister along with 4, 3/16" holes to accept 10-32 machine screws. take a 1/4" NPT pipe flange and atatch it to the bottom of the canister with the 10-32 machine screws, appling a gasket of silicone between th flange and Canister as well as arround the heads of the screws to prevent vacume loss when in operation.
next thread in a 1/4" short pipe nipple into the 1/4" pipe flange that you just attatched to the canister.
Onto the 1/4" nipple thread a 1/4" pipe"T" fitting one end of the "T" fitting should have a 1/4" NPT vacume gage on it to tell you how much negative presure(measured in inches mercury)you have when using the vacume chamber.(at least27" for a good stabilizeation affect).
The other end of the"T" fitting should have a 1/4" valve to shut off the conection between the Vacume chamber and the compressor(now a vacume pump)
into the 1/4" vale thread a 3/8" hose barb and conect the line between the compressor(now a vacume pump)and the Canister(now a vacume chamber)
I made a little stand out of wood to hold the canister from rolling arround while in use and also made a little tray/rackout of expanded aluminum to fit insideto keep work off th inside of the canister.
To opperate simmply open all the valves on your compressors air tank (take drain incl) turn on with the work inside the chamber and watch the vacume gage. when the gage reads 27-28" of vacume shut the valve between the compressor/pump and canister/chamber OFF. and turn of the compressor . if you did all the fittings,gaskets and doors up tight the chamber shopuld hold a good vacume 27" of vacume for atleast 24 hours while your glu dries if not you will have to reseal and or run the vacume pump from time to time to keep the vacume up in the chamber.
I WILL TRY TO POST A DIAGRAM OF THIS SOON FOR YOU ALL TO SEE IF YOU ARE LOST ON MY VERBAL DESCRIPTION. TILL THEN HAPPY STABILIZING
