yuzuha said:Found a new favorite coarse stone : arato kimi PA 220 あらと君 It is the big pink 220 grit aluminum oxide brick sold at epicurian and Japan woodworker.
I have the same, got mine from bladegallery which is the same place (same people) as epicurian (I never new it was pink, I always thought it was white...but then again I am color blind
Yes, as I said, on the softer stones, like the blue and the Naniwa, I have transitioned completely to a trailing stroke. I still go both directions on the Bester. I am pretty sure you will like the Bester 700 a lot. You can really lean into the stone and scrub away and it will not glaze as long as you keep it wet (it will build up some metal, but you can rub that off with your tumb). I rarely use the 220 or 180 anymore because the Bester 700 cuts so fast and it leaves (obviously) a much finer finish in comparison.
Steeldriver: How long do you soak your 220 before hand. I find that I have to soak the coarse stones for a long time (like 10 min) before it really saturates. Until it is fully saturated it sucks up water like a sponge.
