Cheat sheet suggestions?
Hey Mac,
Thanks for the link. I've saved it and will check it out to see what I can use for my cheat sheets.
BTW, if you make the Strait Bend, 'slippery', it's even easier to untie.
Doc
OK, I guess that's the end of this thread. I must say I'm a little disappointed in the lack of participation.
A big thanks to all that contributed :thumbup: and koyote I didn't forget your pictures:
Doc
Cheat sheets are awesome. I have a few laminated cards with different info regarding sea kayaking(VHF channels and what-not) and I also laminate small sections of charts I'm using. Eventhough I use good chart cases, they're not fool-proof. I'm also able to use china pencils with them for plotting that can be erased and used again.
Definately going to make some others up after reading this thread.:thumbup:
How about the edibility test ?
1 Test only one part of a potential food plant at a time.
2 Separate the plant into its basic components - leaves, stems, roots, buds, and flowers.
3 Smell the food for strong or acid odors. Remember, smell alone does not indicate a plant is edible or inedible.
4 Do not eat for 8 hours before starting the test.
5 During the 8 hours you abstain from eating, test for contact poisoning by placing a piece of the plant part you are testing on the inside of your elbow or wrist. Usually 15 minutes is enough time to allow for a reaction.
6 During the test period, take nothing by mouth except purified water and the plant part you are testing.
7 Select a small portion of a single part and prepare it the way you plan to eat it.
8 Before placing the prepared plant part in your mouth, touch a small portion (a pinch) to the outer surface of your lip to test for burning or itching.
9 If after 3 minutes there is no reaction on your lip, place the plant part on your tongue, holding it there for 15 minutes.
10 If there is no reaction, thoroughly chew a pinch and hold it in your mouth for 15 minutes. Do not swallow.
11 If no burning, itching, numbing, stinging, or other irritation occurs during the 15 minutes, swallow the food.
12 Wait 8 hours. If any ill effects occur during this period, induce vomiting and drink a lot of water.
13 If no ill effects occur, eat 0.25 cup of the same plant part prepared the same way. Wait another 8 hours. If no ill effects occur, the plant part as prepared is safe for eating.
And this.....
To avoid potentially poisonous plants, stay away from any wild or unknown plants that have--
Milky or discolored sap.
Beans, bulbs, or seeds inside pods.
Bitter or soapy taste.
Spines, fine hairs, or thorns.
Dill, carrot, parsnip, or parsleylike foliage.
"Almond" scent in woody parts and leaves.
Grain heads with pink, purplish, or black spurs.
Three-leaved growth pattern.
Pitdog, I'm sorry. I just saw that you posted a suggestion and I didn't reply to it.
I don't agree with the edibility test. I believe there are things that would pass and still are poisonous. Besides, in a survival situation, if you don't already know what is safe to eat, then is not the time to learn.
You're much safer and better off, nutritionally, to stick with critters (incl. fish). Also keep in mind you're good for a couple of weeks with no food.
Having said that, I value and thank you for your input. Sorry I didn't see it before.
Anyway, the cheat sheets are done, at least for now. These are going to jwilliams to fill out his survival kit, along with a new, easier to unravel, jute pouch. The biggest PITA about these things is trying to cut them out of the laminate, freehand. I have to come up with a better way. (Open to suggestions :D)
Overview:
These are 2-sided, so there is another 9 sheets on the flip side.
Doc
Doc- put a bit of leather in the center, and use a drafting compass with a small razor in screwed in instead of a lead. easy as...pi
Very nice Doc! I've been thinking about similar things. I post a while back about wanting a pocket plant/tree guide for my region (PNW), and I'm still searching one out. Someone posted about having a drawing journal along with the book(s) to help in learning them which I still really want to do, but I'm always pressed for time.
Do you have a first aid card? Or a what to do if lost card? I took a Wilderness First Responder class, and he had a little pyramid to help us remember everything to do, I've thought about making that onto a card as well.
You could make two of the cards with small holes in the middle that could be turned into emergency sunglasses!
Just some thoughts.
Overview:
Doc
Awesome sheets! I got these today in the mail, put em in, and sewed up the pouch. Awesome PSK. Ive played with it enough that I am now comfortable with it totally. I have carried this everyday, and would feel naked without it. The sheets are well done, easy to read, and all great info. I didnt look at this thread ever, so I would be suprised at the content in the cards. I talked with Doc about my suggestions via email, and wanted to see what everyone else came up with when I got them. I am impressed.
Thanks Doc! You are one of the guys here that makes my time spent here so enjoyable.
No teddy patch though.:(;)
I just caught up with this thread. Some great ideas, Doc. How about a very simple guide to fishing. I am always amazed at how many people don't know how. One side of the card could tell how to rig a line, the other how to use it and where. Adding a tad of utility, the hooks and line could be sealed inside the two sided card.
Or... with a simple screw fastener from the office supply, the "deck" would become a hinged book that can be opened and used to fan a fire. If you include more cards than would fit in the kit, the user just selects the ones they find most useful to them and leave the rest out.
Codger :thumbup:
Dammit, sorry I missed this thread doc.
Are you still open to more idea's, or is it a done deal?
Thanks guys.
Codger, your posts are always great. What would you put in? Remember it has to fit on a small diameter sheet. BTW, the card is printed on both sides, but is a single piece of paper.
Or... with a simple screw fastener from the office supply, the "deck" would become a hinged book that can be opened and used to fan a fire. If you include more cards than would fit in the kit, the user just selects the ones they find most useful to them and leave the rest out. Codger :thumbup:
I agree about selecting the ones you find useful and leave the others out. In my kit I include the ground to air signals because I can never remember them but don't need the knot cards, for example. I confered with jw about the things he wanted, and tried to make them, accordingly.
Doc
...Codger,... What would you put in?....Doc
A leader or plain length of line such as come tapered, weighted etc. for fly fishing, Some hooks, likely three sizes plus a small fly. All are very flat and take up little space.
Why a fishing kit and instructions? It gives the person something to do besides run in circles screaming. Whether or not they catch anything (short term) doesn't matter. Fishing plants them. And gives them time to calmly reflect on their situation while at the same time giving them the feeling they are being proactive, doing something about their situation. I think of it as providing brain food whether it provides belly food or not.
