- Apr 29, 2014
Hi Guys,
I've been researching bladesmithing for a few years now, and am finally in a position where I have the space and funds to move forward. I've also managed to convince my wife that I (probably) won't kill myself, which helps.
What I'm hoping for in this thread is to lay out all the plans I have and basically see if anyone can spot major flaws or problems that I haven't thought of, before I make any permanent moves. I'm a bit of an amateur chef, so the goal of me getting into this hobby is to eventually smith some decent kitchen knives.
Here's what I've got:
JF #1 venturi with LP kit
5 lbs satanite - Ideally some day I'll use any leftovers for Hamons
1/4 pint ITC-100
Enough wool for 2 inches
Hard firebrick floor
This air compressor as my shell http://i.walmartimages.com/i/p/00/87/03/50/30/0087035030003_500X500.jpg
Plan is to sand down the tank, cut 2 doors, weld on a tube with set screws to hold the burner, line, mortar and cure, ITC-100, high temp black paint on exterior.
An anvil is where I'm really lacking. I've read that it's all about the weight under the hammer and the quality of the surface. I have 3 ft of I beam; my plan is to stand it up vertically, weld something like a 1"x3"x3" block to one end as the striking surface, then sink the other end in a bucket of concrete and bury that in the ground or in a stump. I know that's pretty rag-tag but I can't seem to find any reasonable anvils anywhere as of yet.
I've decided that I'm going to skip mystery steel and just order from NJ steel baron or another reputable company. I'm hoping this will take a lot of the variables out of what I'm sure will already be a very difficult first run. My goal is either an 8" French/German chef's knife, or a 210x42 mm Gyuto. I feel like this is way out of my league as a first effort, but I don't mind scrapping a few pieces of metal as a learning experience.
For metal, A) I need something relatively easy to work, would prefer higher carbon as I don't mind taking care of knives, and ideally something I can easily HT and quench at home with no fancy gadgets. B) I do not know what thickness and width I should be getting when I order steel, given what I'm trying to make.
Out of the following, which would you guys suggest? Again, looking for beginner friendly, easy to HT, relatively suitable for chef's knife: 15n20, 1084, 52100, 5160, 80CRV2
For tools, I'm planning on using an angle grinder w/cutoff to chop the stock down to a rough shape and forge from there. I've got a good hammer, but will have to use vice grips until I can make tongs. I have some good whetstones right now, and know that I'll need some good files. I also have an assortment of basic hand tools. Is there anything else I'm absolutely going to need to get the job done?
Sorry for the length, and thanks for the help!
1/4 pint ITC-100
