- Sep 19, 2004
Spyderco Karambit. Great Knife!
Price: $101.95
Flat Rate Shipping... Our Thomas/Spyderco folding Karambit is all-stainless with an arcing blade shape that carries through into a curved handle creating, in a sense, a large claw. Positioned at the end, for an index or pinky finger, the ring lets you to swing/rotate the blade into different grip positions. When closed an accessible nick/recess in the steel handle channels the thumb to, and then over, the Spyderco Round Hole for immediate blade deployment. To facilitate opening the blade even quicker, the hole is expanded to 13mm in diameter. On the backside, the handle scale is laser cut into a Chris Reeve Style integral Linerlock. The blade is made from VG-10 and double flat-ground with a finger guard behind the cutting edge and a sizeable thumb-positioning spine cusp above the hole. These ergonomics merge making the piece feel comfortably curved and easily controlled in the hand. A flat, broad steel clip completes the package and is outfitted with the necessary hardware to position for tip-up/tip-down and left- or right-hand carry.
Spyderco Karambit Specifications:
Blade Steel: VG-10
Blade Thickness: 3/32" 2.5mm
Clip: Stainless Steel
Edge Type: PlainEdge
Hole Diameter: 1/2" 13mm
Handle Material: Stainless Steel
Length Blade: 2 1/8" 54mm
Length Closed: 5 1/32" 128mm
Length Cutting Edge: 1 13/16" 46mm
Length Overall: 5 1/32" 128mm
Weight: 5oz 145g
Spyderco Karambit
Price: $101.95
Blade Steel: VG-10
Weight: 5oz 145g
Spyderco Karambit
