Ah-ha Sam, You have hit on the solution to your handle problem without knowing it. Drill the main handle block out to a 1/4" hole that is 1/2" shorter than the tang to be buried. Burn in the tang until it is a good fit (still leaving that extra 1/2" exposed) clean out the hole with a long thin scraper hook to get out all the char. Take a piece of 1/2" thick ebony, about 1"X1" ,and drill two 1/8" holes to start the tang hole. Using a coping/jewelers saw, saw out the web and then file the wood until it is a perfect fit for the tang. slip this on the tang and glue the main block to it with 5 minute epoxy (just the two wood pieces, not the tang). Carefully, pull it off after the epoxy sets, but before it can firmly attach to the tang (I wax the tang before this step). Let it cure, pre sand the end to get the face smooth and polished (as in any knife without a guard). When all is ready, drip in some slow cure epoxy and install the whole assembly on the tang. After cure, grind the block to shape (This is where you can trim out any slight misalignment with the handle and blade). Sand and polish as desired. The black bolster and light handle is the classic look in Japanese food knives. I like an oval to slightly egg shaped profile. Avoid thick handles, but long is good. Depending on the knife most of my handles are somewhere around 5/8"X1" oval and about 6-8" long. Small handles are 1/2"X3/4" and 4-5" long.
As to the shape, It would be best described as a Japanese grind butchering knife. I can not recall any blade shapes that have a curve like that in classic Japanese cutlery. Maybe you can market it as a 4S knife (Sam Salvi Sushi Slicer). BTW, the forging method you are using is honyaki (One steel forging). Kasumi is the forging method using two pieces of metal ( san-mai forging).
I am going out to the forge now. I have an order for a D-2 sashimi knife that I am going to grind. I'll try and post some photos later.
Stacy
