- Oct 1, 2012
Been too dang busy to get a worthwhile post in here, but just wanted to say, keep it coming Mac, I'm reading with interest.
In case you missed it, there is a post above showing a picture of just threading the cord through the Tek-Lok rather than the belt-loop and using that for the dangler, if you decide to stick with the Tek-Lok.
Looks good Mac. I had a custom leather setup built for a two-knife dangler set a few years back. It took a couple of tries to get the drop loop portion of the dangler the right length, but when we got it to fit at the hinge-point of my hip it just made a great sheath. I can jump in the truck with it on and it doesn't hang up or gouge me or get caught in the seat. The UKE would be real easy to adjust that length, where I had to get a longer loop built.
Just click 2 with the next Survive knife order. Problem solved (except paying for them).
I too have gravitated to the old style leather loop on my 5.1. I did not try to dangle the knife when using the clip.
B]Texas_[/B] good job on tying the clip into place :thumbup: As tight or as loose as she needs it, the options are endless![]()
Yup, screws will gouge the crap outta slots without a washer of some sort. I've actually thought about having some flanged steel inserts made at some point.
Chiral, I wonder if you could find a small enough hole saw to make short work of those washers. If not, I used to do something similar as a webbing backer, and found a cheap handheld sheet metal punch saved a lot of headaches in putting holes in tiny pieces of Kydex.
