GarageBoy,
If you hold a chisel ground knife perfectly vertical and sharpen on the Sharpmaker (bevel side, of course), then it would probably be too thin (since you'd either be sharpenign at 15 or 20 degrees. However, alll you need do is tilt the knife past vertical and sharpen that way, to change the angle. You won't get angle control like with something such as the Edge pro, but it will be pretty good. In fact, the sharpmaker trick would very quickly teach you what angle to lock your arm at to sharpen the beveled side of a chisel grind.
Navy knifer: glad I could be of service. I get a lot of help from folks here through discussions just like this, so I am just happy I can help someone out! Thanks to you too Garage Boy for passing on chisel sharpening info too! NK, I have an Edge Pro Apex wih stone upgrade. For a very comprehensive system to do chisel grinds and others too, I recommend the Edge Pro Apex with stone upgrade, the plate glass from Lee Valley and the lapping grit, a 4000 grit waterstone from lee Valley, and some wet/dry paper. Your sharpmaker will be great for touch-ups, serrations, scissors, etc. Use the Edge Pro for most other sharpening needs, including sharpening the bevel on chisel ground knives. Use the plate glass and sandpaper and 4000 grit stone to lap the backs of chisel ground knives. The plate glass and grit will also be awesome for lapping flat your Edge pro stones (they are watertstones, so they require lapping more frequent than other types of stones.) The Edge pro does come with sand for lapping, but they just suggest lapping on a concrete block or whatever is handy. Also, the sand included I think isn't as aggressive as the SiC grit that you can get from Lee Valley. With the plate glass, you can lap any stone you have any time you want. Also, you can use the plate glass and rough grit paper to thin out edge bevels. If you take, say, a folder from Benchmade (40 degrees inclusive) and you want to thin it out quite a bit, say 12 degrees per side with a 15 degree per side micro bevel, you'll probably end up needing to lap the Edge Pro stone afterwards to make sure it is flat for the net tiem you use it. Instead, slap on some 60 grit paper on the glass (spray the back with water and it will "stick" to the glass), spray on some water and use that to thin out thick edge bevels, then go to the Edge Pro. This actually will save a lot of time. not that the Edge Pro is slow at hogging steel at edges (it is way faster than most systems). It is just that free hand hogging is way faster. That is whay I got that 200 grit 3"x3"x8" stone for: I can thin out a thick bevel in a jiffy on that, clean up on the Edge pro with the coarse stone, and polish the bevel in minutes thereafter. 60 grit wet/dry is available all over the place too!
By the way, if you did get all of that gear, you'd end up with a set-up like me. I have an Edge Pro, the Lee Valley stoen pond as mentioned already, and a sharpmaker. I also have a nice 2x42 grinder (belt sander), but I make knives as a hobby in my spare time
If you ever want to go powered, start a post about 1x30 belt sanders and I'll fill ya in! I use all of my sharpeming gear too: just depends on what I want to do, and with what edged tool. I'd hate to sharpen a machete on anything but my grinder, I'd hate to do serrations on anything but my Sharpmaker, I'd hate to try to sharpen a knife from scraping sharp to scary sharp infront of the TV with anythign but my Edge Pro...
