First off I'd like to say I'm not sure if this is a proper introduction, I haven't joined a forum in years so I'm not sure what the protocols are these days. I have lurked on this forum a bit and have heard nothing but good about this site, so I hope you all will welcome me with open arms
Anyway now that's out of the way lets move on to my question. I will prefix this by saying I have searched the web and asked several different people with knowledge on the subject and I can't seem to get a straight answer. Basically I'm a Kali practitioner and I'd like to get a custom fixed blade that will excell in the role of self defense. The perticular knife I'm looking at can only be made with a chisel grind, specifically a zero chisel grind (no secondary bevel). I have heard that chisel grinds can only cut in one direction effectively, is this true? So if it was ground on the right side of the blade and held in my right hand and I cut from right to left (we call this angle 1 usually in Kali) or if I cut from left to right ( angle 2) would a chisel ground knife cut equally effective or slightly better/ worse or even not at all for both angles, depending on which side of the knife is ground and which side is flat.
Keep in mind this is purely from a stand point of self defense I don't really care about how it performs in everyday cutting chores, unless it is relevant. So that about sums it up, I understand Emerson almost exclusively uses the chisel grind and the zero chisel grind, so I have to wonder why they would choose to use that grind if it can only effectively cut in one direction since clearly they market their knives for self defense application first and foremost. Hopefully you all can offer some insight on the subject. Thanks.
