Chisel Grind question
Does a chisel grind go on the right or left hand side of the blade depending on being right or left handed?
Thanks,
BJ
Depends on the cut you want. If you wand a deep aggressive straight penetrating cut, grind the out side. If you want a cut you can dip into and out of making a concave cut. grind on the inside.
In a whittling away from the body, inside being bevel toward material to be cut, out side being flat toward material to be cut. In a food prep on a cutting board situation inside ground will be bevel toward the off or material holding hand, outside will be flat toward the off hand. Did that make any sense?
I have made and used loads of katashinoge (bevel on one side or one ridge-line) ground blades over the years and don't have a preference for general use. In the kitchen, for chopping, or in a sword I prefer outside ground.
