David Martin
Moderator
- Apr 7, 2008
I sharpen my blades of S30V to around 300 grit all the time and have not noticed micro chipping. Plus, I almost never polish an edge and haven't noticed any micro chipping. DM
Well @&$#.... I'm over here thinking I learned something new from a renowned knife maker, just to get kicked in the balls and told it's bs [emoji34] ... god the internet sucks tonight.[emoji17] lolYep, a bunch of flapping in the wind right there...
I'm going to try something similar next time I sharpen. Wondering how a combination of 400 grit and 1 micron or 0.5 micron would turn out...My guess is that Spyderco uses somewhere between a 320 and 400 grit belt to grind the cutting bevel. Then they polish the burr off with a buffer. I normally see an ultra thin shiny line at the edge of the edge; a microbevel that's quite shiny. That probably comes from the buffer; at least that's what I've been told here.
So maybe sharpen on a stone of approximately that grit and then deburr, at an elevated angle, on the finest stone you've got. It's worth a try. It's also sort of what John Jurranich teaches in his book; more or less.
Brian.
I tried the technique where the bottom of the stone is placed at the heel and finish going down to the tip orienting the scratches for draw cuts and slicing. The only thing is the play in the stones puts on a visible slightly more obtuse angle at the heel portion. I've seen the video where Josh does this, but just wonder how you account for this and make it more consistent?
I was thinking this too and it makes sense. I will try it when I go to touch up next time. Need to get some different materials and try out this edge. Feels aggressive but will shave hair and wave cut phone book paper just like the best Spyderco factory edges.Not sure how Josh does it, but if you place your palm at the base of the stone with slight pressure (basically rest it there), it will keep the stone consistent.
Reprofiled my SnG this weekend stopping at 400 grit and stropped with 0.5 micron. Talk about an aggressive slicer.
Hoping Josh can chime in here on this... I've been using the WEPS for a couple years but tried a new technique to finish. I have always gone with the typical forward up and away strokes, orienting the scratches in the direction of the tip. I tried the technique where the bottom of the stone is placed at the heel and finish going down to the tip orienting the scratches for draw cuts and slicing. The only thing is the play in the stones puts on a visible slightly more obtuse angle at the heel portion. I've seen the video where Josh does this, but just wonder how you account for this and make it more consistent?
Thanks for the response. Sounds like that takes some serious coordination/concentration which would take some practice lol. I will definitely give it a shot though.Funny you should do that... I just put a 400 grit edge on my 0561 w/ a light stropping after. Love this edge for edc!
Anyway, yes you are correct the play is maddening. What I do is actually vary the pressure points during the stroke. I have finished the way you described for years...1. edge leading will have the best chance of removing the burr/wire edge fully and 2. the grind direction has a large play in the effectiveness of the edge (as you will find if you haven't yet).
So what I do is put pressure on my palm part of the stone at the raised position at the heel of the edge, then transition through the stroke to where I have all the pressure at the tip of the stone when at the tip of the knife. Hope this helps.
