Hi, tsdevanna: Glad you join the discussion.
Unfortunately, I can not give you a straight answer to your question. Like I told possum, this is not how it works or even should work. I know much less about chopping than you do, so who am I to tell you how your knife should look like. Also, the weight distribution will depend very much on the preferences of the user.
However, what I can do is give you preditions what will happen to certain properties if you implement certain changes. If you have for example a specific blade that you are not completely happy with. I can tell you how much kinetic energy you gain/lose when you move the COM by a certain amount or if you change the weight distribution around. I can tell you where your sweet spot will be, and can make an approximation on how wide the sweet spot will be, I can make a resonable guess on the shock you might feel if you have a certain blade position that you would like to hit the blade. I can also give you ideas on how much faster/slower the blade might be if you make certain adjustments to the weight distribution.
But for all that, I need a starting point first. Meaning you have to give me a weight distribution to work with first. This could look like the following, let's say you have a knife that has the following weight distribution: 1 1 1 2 2 1 1.5 1.5 1 1 1 1 1 2 2 and you what to know, how much faster or slower will the knife be if you change the weight distribution to 1 1 1 2 2 1 1 1 1 1 1 1 1 2 3, how the sweet spot will be affected how much energy you gain or lose if you still swing it with the same velocity etc. That I can tell you before you do any modifications to your blade. It could also work this way. You give me a weight distribution of an existing blade and you ask me how to change it to get the maxiumum momentum without changing the COM. Then I can make a suggestion and tell you how much you gain, and how certain other parameters like the pivot point will change. And you might reply that you don't like my suggestion because you don't like how the pivot point moved. Now I can make a different suggestion and we can work back and forth till you think you have a reasonable trade-off. Of course with the sample calculations you could do that all yourself, but I am more than happy to assist anybody who doesn't want to slug through the math.
But for me to give you a starting point would be taking advice from the wrong person. Possum might help you with this, and as I see he has already started with it.
Edit: You should view the mathematics as a playground: The role of the model is not to tell you what is best, but to test your theories. It takes a lot of time and money to make a blade, you can make up 10 different blades in minutes for the expense of a pencil and some paper and see what happens and more importantly even quantify the differences if you make your adjustments to the blade. You will also realize that you can not optimize all parameters at once. You can construct a blade that gives the maxium power but if you do not have the strength to swing it, it is no use to you. My brother was once part of a workshop that build high performance human powered boat, so called waterbikes. They build an amazing design: double hull carbon fiber driven by a single bladed carbon fiber air propellor with counterweight which, at ideal opperating speeds would reach supersonic tip speeds. The whole thing was calculated to be able to reach close to an incredible 20 knots.........well....turned out that no humans were actually strong enough to get the propellor to full operating speeds.....ooops. The calculations were all correct an when the put in a very small motor that was strong enough to actually get the propellor up to speed, the thing was flying. Unfortunately, the calculations overestimated the human element substantially.
