- Jul 31, 2002
I'm not sure how to answer this without sounding contradictory. Basically we want the most mass that we can still move at very high speeds. All the things we've been discussing affect this; not just mass.
Yeah, that's probably a good way to describe it. As it was made, I considered it far from ideal, so I had to move the mass around. Of course if I was starting from scratch, as I'm doing right now with a big falchion,Okay, so you want to move the mass, not remove it. I was wondering because I know you removed steel from your kukri-but you had to to move the balance around, it was a finished piece. You added the heavier pommel...
...but still made an overall lighter tool, IIRC.
Mass is factored into calculations of impulse, momentum, force, and such, but so is acceleration and velocity.
If one can greatly increase acceleration of a smaller, or even the same, mass, then something like chopping could be done more easily. I guess it's the baseball bat versus a bullet thing-they could both have the same momentum, but the bullet has greater kinetic energy. And it would be better if you could get the tip of the bat moving as fast as the bullet. Or something like that.
You also raise a very valid point in that momentum and kinetic energy are not dependent in the same order on velocity.
...As a sort of general rule, this is why speed is more of a factor than mass, meaning that it is better to make an increment in speed than in mass. Of course if you can increase the mass without decreasing the speed (which will happen up to some point) then that is always productive, assuming you want to carry it.
Rotational tip speed is proportional to length but that is only part of the total energy and the linear part isn't dependent on length at all. The power has more to do with the total mass and the balance points and you can vary these a great deal in a given length, but at most you are looking at a less than linear effect. The 75% comes from actually comparing a number of similar blades of varying lengths which I did before I looked at the physics, experimentalist after all. Swaim looked at this on rec.knives years before I did. He also assumed there would be a bigger influence on length. Note as well that the total length is what factors into things like the inertial moments.
Possum, I only buy knives that are as perfect as possible for my uses. So mods arn't needed. And neither is changing the design of a new knife except for reprofiling the edges.![]()
