I wouldn't even want to chop a 16" diameter tree down with an axe unless it is my only option which generally speaking it is not.... cross cut saws or chain saw job.
The machete will not break, but you will definitely do a lot of damage to the edge. Machete's are made of tough low carbon steel and kept soft for toughness. This comes at the expense of edge strength, so the edge will deform readily on hard objects. Soft vegetation is no problem, but a tree with knots will do a number on the edge. The blade itself will not break, or it should not.
You have had better luck than me. I have turned machetes into serrated edges chopping wood branches. I have never tried chopping a tree though, lol.
Tramontina uses 1070 in its machetes, very tough stuff that is also used for shovels. Not sure about the hardness, but they are quite easy to hone with a fine file. I have a Scandi grind in 1070 by Ivan Campos, a Brazilian cutliero. Likely he used a different tempering process than Tramontina, though; it is the sharpest knife I own.The machete will not break, but you will definitely do a lot of damage to the edge. Machete's are made of tough low carbon steel and kept soft for toughness. This comes at the expense of edge strength, so the edge will deform readily on hard objects. Soft vegetation is no problem, but a tree with knots will do a number on the edge. The blade itself will not break, or it should not.
