- Mar 8, 2008
Once you hit ~1090 heat treatment becomes more finicky, and the steel is more prone to rusting and is overall less tough. This is why Ontario's use of 1095 in their military machetes is a bit mystifying.
that's why I expect I'll end up making my own 80crv2 machete, it just feels proper... the only real question is will I make a close copy of the tramo 18 or try something diff? I'll likely stick to a 2 foot bar, 1.5 inches wide, and either 1/8 stock or perhaps 3/16... hard to decide
SK-5 seems like a slightly more interesting steel. My only gripe with 1070 is the somewhat higher than normal sulphur at .05% (most others stay to under .03%) ...
I've seen that footage before and as he explains in the video it's because the branches are dead, dry, and hard, and he's deliberately using purposely poor technique that produces torque on the edge. The best way to take those sorts of limbs out is to strike them at the base using the spine of the blade to shatter them off, or else make cuts at an angle near the base of the branch or at a slant away from the branch. He even specifically mentions that at a 15° per side it wouldn't pose any challenge. He's probably got it down closer to 10° per side.
I respect a lot of Cliff's work, but I personally feel as though he has a very narrow understanding of machete tuning and contexts of use, although he makes them work for what he needs them to do. If one were using a machete purely for lush vegetation cutting you could probably take it down to something like 8° per side and it'd do great, but be easily rippled by rigid wood targets. But a more general purpose machete is going to be more like 12-15° per side and it'll perform just fine even in very rough applications.
I tried cutting off a piece of 2 inch bamboo that had fallen over. The 14 inch Tramontina Latin-pattern machete was sharp, but wanted to bounce off. The bamboo wasn't supported and was dried. The outer portion was harder than woodpecker lips - lots of silica.
Interesting video. Std machete use edge angle will likely sustain damage on wood. Likely what happened with mine. At 7 minutes you can see the typical damage I have seen on mine.
