Your clearly too much of a crk fan boy to realize QC has dropped. Look up YouTube videos. Ppl have on symmetrical flats on the blade. Ppl put calipers to them one side it a couple thousand off of the other. That's not tighter then NASA tolerances. My spinning washers aren't tighter then NASA. Again I still like the knife but not worth $425.
They have a really really good warranty if it wasn't for that the knife would be sold. The blades at $125 is a ripoff tho.
The knives are overpriced by today's standards
Worth is determined by what somebody will pay for something- that somebody may or may not be you.
As far as measuring grinds, I have never done it and I AM a machinist of nearly 30yrs..Despite this, I will bite.
What have YOU measured- not some tool on youtube..YOU.
How close should a grind be on both sides? A couple of thousandths measured with calipers? Are you serious? The best of calipers are only good to within .002in..let alone the harbor freight garbage these people are using...and that is with someone that has been trained to use them properly. NASA doesn't use calipers to measure tight tolerances...Right tool for the right job and all- if they are within .020, that is good for me- Most people don't have that kind of ADHD to even see that.
Here is an idea of the tolerances they try to hold.
The blade blanks are ground flat and parallel within .0005in over the length. Most of the time, they are within .0001-.0002 flatness and parallelism.
Many of the turned parts are +.0000, -.0002in on diameters.
None of which can be measured with calipers.
Did you buy your knife second hand? New? None of this should matter if it's authentic- Passing through the shop 3x shouldn't happen to correct an issue. That part is true..but I don't know the details on that. You probably need to have a frank conversation with Angela, Matt or Tim to get that rectified to your satisfaction.
I have no idea about your washers spinning..No idea what is going on with that. There are too many factors to consider. Personally- I don't even look to see if my washers on any of mine are "spinning" as I am too busy using it to even notice. Weird.
To address your fanboy assertion...Sure; Everyone is a fan of something...but to be clear...I am a fan of Shirogorov, Northwoods, Case, GEC, Queen Cutlery and several other knives too. I know the most about CRK. I live close to them. Have made parts at different points in time for them. Make tools for them.
It's really a paradox that I can buy knives from them, and I buy quite alot- both new and on the secondary market and don't have any of these issues.
The sample size must be too small if you are familiar with statistics.
To put it another way, and I have stated this before. If there isn't a problem, then people don't say anything..but when there is a problem, they shout it from rooftops (see youtube). Stating that there is a QC problem in these vids or a few times on a forum like this one, makes the problem seem more prevalent.
See bolded statement in the previous paragraph if this statement doesn't make sense.
