Chris Reeve SABLE review
I have intended to buy this damn knife since 1993 and FINALLY got one. Thanks Murray @ ProEdge - excellent service from a fine gentleman and fellow cop.
A more thorough review will follow, at the end of the month, after the caribou migration gets moving, and the herd is downsized/my freezer upsized. :eek: ;) :rolleyes:
But first impressions last forever, so here goes.
Out of the box - very sharp, edge is perfectly symmetrical, blade coating is absolutely flawless.
Toward the point, just past the "tanto-ish" corner, the bevel grind is uneven, slightly (still symmetrical, though). This just may be because of the way the hollow grind and this point style meet, I don't know. Also, the thumb grooves on the back of the blade are too shallow to really improve purchase at this part of the blade, and because the handle is smooth at this end, it makes choking up on the blade less secure than it could be. The smooth part I'm talking about is where the handle meets the guard. It is constricted for about 2/3 of an inch and this portion is not knurled. I don't think it will affect my ability to use the knife for close, detailed work, because the knurling is so well done on the rest of the handle that the knife should still be quite secure. Time will tell.
Most CRK one-piece knives have a double guard, but this one only has a single one. Perfect for a camp knife IMHO, as the second guard gets in my way. Where the second guard would be, the now-flat part is ground a little uneven, meeting the blade about 1/2 mm further up on one side. Barely noticable, but it is there.
One last nit to pick, when the buttcap is screwed down, metal to metal (very tight by the way) the lanyard hole is off center by about 20 degrees.
In fact, of the things I mentioned, this was the one that was the most obvious, and to me, annoying.
I studied this knife VERY thoroughly last night. These are the only issues I could find, and they are very minor, almost invisible. In fact, I will likely never notice them again, because this knife is here to work, and work it will! If I was a non-user type collector, I would consider calling CRK to remedy these imperfections, but that is not the case.
Overall, I am thrilled with the knife, and can't wait to give it a full workout. It looks like it will be a winner. I will also post on the Wilderness/survival forum the contents and functionality of the hollow handle.
I do have a question...
The sheath is beautiful, but I am concerned with the snap closure on the belt loop. Is it secure? If not, what do you suggest?
Thanks for reading
Jim
Hey Jim...
Agreed with you there..
Murray is a good guy to deal with...
The CRK one piece line is a fine executed knife..I've worked on many of Murray's CRK and enjoy working with them very much...
Jim Scribes
"One last nit to pick, when the buttcap is screwed down, metal to metal (very tight by the way) the lanyard hole is off center by about 20 degrees.
In fact, of the things I mentioned, this was the one that was the most obvious, and to me, annoying."
Turn the inside O-ring 20 degrees in the opposite direction..
It should fix this problem.... :D
Yupp,, I can understand that being annoying,,no doubt...
Good luck on the Caribou hunt,,where are you going??
You in Canada ??
I'd like to do that one of these days...
Deer hunting is about all I'll get this year...
Anyhoo,,glad you like the knife..
ttyle
Eric...
Hey there Normark,
Yes I'm in Canada. If you look at a map, look up!
I'm located in Fort McPherson, sixty km north west of the Yukon border, in NT. The porcupine caribou migrate from Old Crow, YK through Wright Pass, which is right where the Dempster Highway meets the Yukon. It is pretty easy hunting, except there is no snow yet, so we have to walk from the highway instead of using snowmobiles. It is quite a good scenario for testing knives, because the chances of of our group of 4 or 5 getting 10-20 animals is pretty good, if not guaranteed. I hope so, 'cause I have 4 new knives I want to test. Seems like alot of animals, but there are many elders who are too old to hunt, so we like to help them out.
Yeah, I would like to get out and do some deer hunting. I have spent alot of time in Manitoba and north west Ontario, but never hunted deer?!? Love that sausage, though.
Since you are in the sheath business, I should ask you, have you had any problem with the snap coming undone on the CRK leather sheath's belt loop? Any suggestions on how to prevent it?
After I carry this knife a bit, I'll likely contact you re: a kydex solution, but I still want to keep the leather one if it can be secure.
Regards
Jim
Hey Jim...
Sounds like fun..
You even need a partner,, let me know..:)
I've got a .308 norma mag,, just itching for Caribou... :)
No problem on the Kydex..:)
Can take care of that for you...
As far as the snap goes..
Is it not holding ??
You may want to drop Anne a note at the CRK forum..
They'll take care of that for you in a heartbeat..
ttyle
Eric...
thanks for the informative "1st impression"- of all of the midsize CRK fix blades I like Sable the most because it has the highest grind, along with single gaurd as you stated.
