Ah, sorry for the confusion JaGWIRE. I prefer Arturo Fuente 8-5-8 maduro wrapper. I also like La Viejo Habana and H. Upmann which are all fairly reasonable. Having said that, you will probably find that you will be more willing to spend a few bucks for a cigar after you smoke some and realize the difference between cheap and good. I try to stay in the $3-4 range because I'm a cheap SOB. When you find the brands you like the best and want to buy a bundle of 25 or so then you should check out the sites listed above. You will save quit a bit that way.
You think so? I've found just the opposite. Of course, if you smoke them too hot (usually because you've packed too loosely), you can get some tongue bite. But once you learn to keep a cool smoke going, I find pipes are even milder than the mildest cigars. I should mention that I'm blessed to live near some very fine tobacconists. I've only ever smoked fresh tobacco...no packaged stuff. I suspect packaged pipe tobacco would pack a bigger bite with all the chemicals/additives etc.Pass on the pipes for now, they're a bit harsher, and it takes a good amount of effort to get the perfect bowl.
Drop by http://www.smokersforums.org and tell them Matches sent you. Good people and good conversation![]()
