- Feb 23, 2009
Sweet, ya got one there for Mama Lady
Thanks man! These big blades are right at 3/16".
Yep, a lot of saw blade knives made without heat treating. My father & I started with saw steel back in 1981.Welcome, lots of nice blades there. I like that big clip pont with the false edge right behind it too... I measured our blades this evening..All but one were right at 3/16" just like yours, the other one was a little closer to 5/32" but it was a somewhat smaller blade..
growing up around here "sawblade steel" was the gold standard by which all knives were testedEven the corn knives and tobacco knives were all sought after in sawblade steel..In truth though most of them were probably not even heat treated
I still think its very good steel when you heat treat it right. We normally do a short soak at around 1475° and into parks..
Nice lookin knife.
Temper the same & the water quenched blade should still be harder.
Try the brine quench, it should be fine.
I found which steel it was .Saw is made in Turkey from German steel .It is 1.25 % carbon and 2 % Tungsten .Remember too guys, Mr Natlek up here is from Macedonia..What is normal for our saw blades might not be normal for his.His may well be made of something with much higher carbon than ours.The germans made a lot of steel like that.
As we're discussing saw blade knives. I recently tried making a knife out of an old saw blade. I don't know the steel, but it was hard enough that drilling through was a real pain, but it still cannot hold an edge. I don't get what causes this distinction, that it is almost too hard to drill through, yet it doesn't hold an edge.
You are correct, it does file quite easily. Would a good tempering of the steel fix the issue, or should I just find a different steel?Drilling 45 RC steel is incredibly hard on HSS drills, but no one would like how a 45 RC knife performs. The distinction is that drilling is a poorly correlated test to sufficient hardness for a knife because it's a very intensive operation. Unlike a file check which is an attempt to make a simple cut, a drill is extruding metal at the center and cutting only where the flutes start. I'll bet that steel files easily with a good file.
