Niall88
- Aug 29, 2022
Hey gang, I like big knives, don't mind spending some money on top quality as you can see in the background. However, once in a while my strings get yanked, even by an inexpensive knife. Check out this CJRB Frack. Only China could do this for $59! What an insane price! If I was not a little knife piggy, enjoying owning a number of them, I could easily live my life satisfied owning just this cheap masterpiece. It feels and performs like any knife many times its price. Solid as a rock and I like the feel of the steel scales. Feels fantastic in the hand, perfectly comfortable choil position. Thumb hole deployment, as sweet as any Spyderco. Simple, minimal clip, nice and tight and works perfectly. Not sure if the AR-RPM9 steel is anything exotic, but cannot expect super steel at this price. If this knife was not $59, I would not waste your time with this post. Because these days, so many knife designs look so similar and the styles overlap. But for $59, geeze, what a bargain!
UPDATE: 9/13/24 - The AR-RPM9 is about the worst steel on the planet. All I did was slice some ends from some tar paper when roofing and the metal went completely dull. I guess I learned my lesson of why a knife is $59! Go ahead, say "I told you so!" I deserve it!
WEIGHTS & DIMENSIONS
| Blade Length | 3.9" (99mm) |
| Blade Thickness | 0.13"(3.2mm) |
| Blade Finish | Stone Wash |
| Blade Grind | Flat |
| Blade Material | AR-RPM9 |
| Blade Hardness | HRC59-61 |
| Blade Style | Drop Point |
| Handle Material | Steel |
| Clip Material | Steel |
| Pivot Assembly | Ceramic Ball Bearing |
| Lock Type | Button Lock |
| Overall Length | 8.9"(226mm) |
| Closed Length | 5" (127mm) |
| Weight | 150g/5.29oz |
