- Mar 6, 2015
I guess technically this is called the hamon line. I am trying to do this on my razors and maybe a knife later. I got some furnace cement at the hardware store, I am using it straight, without mixing anything else with it. I packed it on fairly thick, 1/4 inch thick, and let it dry for about 20 minutes until firm. I put it in for the heat treat. When it comes out the clay has puffed up and expanded to the point I wonder if it will be effective. It also flames up pretty good when I quench.
Seems like this is not right? Also, do I leave on the clay for tempering?
Is ferric chloride and vinegar mix good for darkening the line after finish grinding. This is the solution I use for Damascus. How long should I soak it?
Trying to find my way along in this big ol' knife world, any advice is appreciated.
